Author Topic: Towbar wiring  (Read 1681 times)
mantahatch
Towbar wiring
« on: 19 April 2010, 08:45:57 »
On Saturday I fitted my detacable towbar, then got onto the wiring. Found the multi connector plug in the rear panel and checked which was what wire with a multi meter. All ok is except the brake lights. Now I think I have the right wire black/yellow in the plug is the same as goes to the brake lights.
Problem is it has no +12v on it when brake pedal is depressed. car brake lights work ok and the black/yellow to the trailer socket goes into the loom and travels towards the front of the car.
Now I am assuming the other end needs to be connected somehow.
Car is 2003 2.6 CDX saloon.
Thank You.
Re: Towbar wiring
« Reply #1 on: 19 April 2010, 08:51:06 »
Thank You.
The wiring plug in the boot is wired via a 'relay' base for a 'Trailer check control' relay which, on your car is behind your glove box (preface lift above driver's feet) You either need to fit the 'relay' (sub £20) or bridge the terminals of the base behind the glove box. If you search hard enough, I've posted the details a few times.  :y  :y   :y
I'll see what I can find....  ;)
« Last Edit: 19 April 2010, 08:51:37 by Andy_B »
Re: Towbar wiring
« Reply #2 on: 19 April 2010, 08:55:05 »
Ta da! I must be getting better with this search routine ......  ;D
90463123 is the relay
http://www.omegaowners.com/forum/YaBB.pl?num=1175364013/0 is one of many trailer wiring threads  :y
mantahatch
Re: Towbar wiring
« Reply #3 on: 19 April 2010, 09:42:02 »
Thank you Andy B.
Much appreciated.  :y
