Author Topic: electric rear window  (Read 3111 times)
p.beckwith
  • bedford
« on: 24 April 2010, 12:03:32 »
hi all
  i have one window on rear that opens fine and when asked to close  has a mind of its own   if you use rear switch  and if you use drivers switch   BUT if you just tickle the drivers switch it DOES fully close ????   would this be the card people are talking about ??? if so any idea on replacement cost ????
Re: electric rear window
« Reply #1 on: 24 April 2010, 14:37:01 »
clarify the symptoms better please ;)
p.beckwith
  • bedford
« Reply #2 on: 24 April 2010, 19:03:25 »
when i attempt to close window from either switch,  if i just try one touch  to close, the glass goes up and down as if its got a mind of its own
 only way i do close it is if i gentley pull up the swich so as to close it one inch at a time ????
only 1 window does this ??
 not sure what this talk is of door cards ?????     paul
charlie
  • sunderland
« Reply #3 on: 24 April 2010, 20:18:22 »
I get this with one of my windows,THis window happens to be the one that got smashed.I dont know if i've fitted correctly,or a piece of glass is on the mech./wire or the glass is getting caught on the seal.I didn't have the problem before the window was smashed.
« Reply #4 on: 24 April 2010, 20:20:02 »
have to tried resetting them?
joshwyatt
  • Oxford
« Reply #5 on: 24 April 2010, 20:29:34 »
I had this on a previous Omega, press the switch and help the window up with your hand.
So, place your hand on the window and push it upwards and press the switch together, that ought to help. I've only ever had it in warmer weather.
« Reply #6 on: 24 April 2010, 20:41:16 »
I had this on the drivers side rear. After disconnecting the battery to do another (unconnected ) job and then reconnecting it, I found the window worked as it should :y
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #7 on: 25 April 2010, 18:50:34 »
A door card is simply the interior trim which is attached to the metal frame of the door  :y
Welung666
« Reply #8 on: 25 April 2010, 18:57:12 »
Try a piece of tailors chalk up and around the runners when the window is down. Works wonders ;)
Page created in 0.028 seconds with 20 queries.
