Author Topic: Chipping tractor help  (Read 3986 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 26 April 2010, 14:58:46 »
Hi all my ecu has arrived today so want to fit my chip as I broke the last ecu.how did you all remove your old chips as that's how I broke my ecu?thought I'd ask! 8-)
scream if you want to go faster!!!
MickAP
  • South Derbyshire
Re: Chipping tractor help
« Reply #1 on: 26 April 2010, 15:11:34 »
Assuming you may have read the "How too" if not here it is
http://www.omegaowners.com/forum/YaBB.pl?num=1232908603
I followed this with help from other forum members.
Only problem I had was my chip needed to be socketed onto the board to enable the new chip to be installed. In other words if your chip is soldered in then it needs someone who can fit you a socket so you can change chips easily.
I had a forum member do mine, very nice man indeed :y
Have you got your replacement chip yet?
Mick ;)
« Last Edit: 26 April 2010, 15:12:36 by MickAP »
mr ICE man
  • dolgellau wales
« Reply #2 on: 26 April 2010, 16:36:00 »
Yes got the new chip and socket but removal of old chip as my problem as that's what damaged my ecu last time.can anyone on here help??
« Reply #3 on: 26 April 2010, 16:39:48 »
I take it that the chip is soldered in?
To be honest, if you're not used to, and equipped for, reworking electronics it's probably best that you entrust the job to someone who is. I would suggest taking it to a decent local TV repair place, if you can still find one, and ask him to desolder the IC and fit a socket.
« Reply #4 on: 26 April 2010, 16:45:03 »
I agree with Kevin Wood above :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 26 April 2010, 16:56:18 »
Do you have a local TV/Video repair man nearby?
if not, give me a yell
« Last Edit: 26 April 2010, 16:57:25 by Dave_DND »
Radio & Decoding Technician
www.dndservices.co.uk
mr ICE man
  • dolgellau wales
« Reply #6 on: 26 April 2010, 18:21:01 »
No!!I live in middle of nowhere!I'm pretty good with electronics but having broke my last on i'm not confident now!so dave I'm giving you a shout!
