Author Topic: Automatic - interlock relay  (Read 3970 times)
I_want_an_Omega
« on: 24 April 2010, 08:27:47 »
My car has a problem where sometimes you can't take it out of park without pressing the yellow tab down. Other times it's ok and you can hear the relay click when you press the brake pedal.
Check control is ok and brake lights work ok.
Any idea what the most likely cause of the problem is guys?
Thanks
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Automatic - interlock relay
« Reply #1 on: 24 April 2010, 09:19:09 »
This happened to me as well but my brake light switch was intermittant ... sometimes the brakelights wouldnt light up and that was when it wouldnt release .... but then you say your brakelights are fine  :-/
« Reply #2 on: 24 April 2010, 10:01:57 »
Often the switch, but can be the solenoid.  Easy enought to check with a meter across the solenoid ;)
« Reply #3 on: 24 April 2010, 12:29:55 »
Haven't you just removed a brake switch ?  ;)  ;)
« Reply #4 on: 24 April 2010, 14:38:05 »
err, no.  Bugger my back attempting it, it will have to wait until I've recovered....
« Reply #5 on: 24 April 2010, 14:47:58 »
It's not the most comfortable or elegant position you need to get into to get to the switch  ;) ;D
« Reply #6 on: 24 April 2010, 14:51:32 »
A useless student is over later to lift front seats out.  While he's there......  ;)
« Last Edit: 24 April 2010, 14:51:45 by TheBoy »
« Reply #7 on: 24 April 2010, 14:53:34 »
Even you'd be able to lie down to do the job if the seat's been removed.  ::)  :y  :y
I_want_an_Omega
« Reply #8 on: 24 April 2010, 18:22:20 »
Are you being towed somewhere then Jamie?
« Reply #9 on: 24 April 2010, 20:18:05 »
Pesky brake switch out, at last.  Had to take the dash out to get the little barsteward out  >:(
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #10 on: 26 April 2010, 14:37:04 »
is the solenoid the bit where the yellow tab connects too? if it is then mine has gone and am wondering how on earth you can actually take it out?
07 Volvo V70 T5 SE ex police
« Reply #11 on: 26 April 2010, 14:48:06 »
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #12 on: 26 April 2010, 14:58:22 »
thanks TB, now how do you get it out?
« Reply #13 on: 26 April 2010, 15:20:08 »
Would need to look again, but would have thought it was obvious with leather gaitor out of way  :-/
I'll get a better pic next time I go out to car :y
« Reply #14 on: 26 April 2010, 19:06:37 »
you won't believe this...
...the little sod is welded in :o :o :o
