Author Topic: Estate Alarm  (Read 3736 times)
pedroMV6
  • York
  • Der Metzgermeister
Estate Alarm
« on: 25 April 2010, 17:57:56 »
If I just cut the wires to the rear side windows, will the alarm activate?
If it does,then what do I need to do?
Or, can I simply connect a wire to both (to keep the circuit) and then remove the pads from the windows?
Re: Estate Alarm
« Reply #1 on: 25 April 2010, 18:32:26 »
Stick a meter on them to see if they are n/o or n/c.  I suspect normally closed, as its a glass break sensor.
pedroMV6
  • York
Re: Estate Alarm
« Reply #2 on: 25 April 2010, 19:23:47 »
That's why I thought that adding a wire in first, before disconnecting them from the glass.
pedroMV6
  • York
Re: Estate Alarm
« Reply #3 on: 27 April 2010, 21:32:00 »
Just went for it - cut one pair off then discovered they simply pull off! ::)
Oh well, alarm didn't go off.
