Author Topic: MAF & Air Temp Connectors  (Read 2312 times)
I_want_an_Omega
« on: 04 May 2010, 16:46:19 »
I'm having a dense moment.
I cant see how to unclip the connectors from the MAF and Air Temp sensors. I can see that there is a tab to undo - but cant work out how to undo it :-/
HELP >...........
Welung666
Re: MAF & Air Temp Connectors
« Reply #1 on: 04 May 2010, 18:19:48 »
IIRC one has a single metal bar you push in towards the plug which releases the clips and the other has a metal V either side that you squeeze and pul. The V ones can be very tight though ;)
I_want_an_Omega
« Reply #2 on: 04 May 2010, 18:33:58 »
Ta
John Lewis
  • Macclesfield, Cheshire
  • Macc is wack
« Reply #3 on: 04 May 2010, 18:56:46 »
Keep pushing the little tab on the MAF plug with the two lines on with your strongest thumb and wiggle a bit using other hand on the two edges that look like clips - it will eventually click and come straight off, once you did it once it will get easier.
