Author Topic: windscreen wipers  (Read 1837 times)
flossbag1
windscreen wipers
« on: 06 May 2010, 02:46:29 »
windscreen wipers are not working on intermitant, tried changing the stalk and no joy, not too sure where the relay is, its a y reg 2.6 v6 which has been converted to a 5.7 v8 but dont think the conversion has anything to do with it, anyone know where the relay is, oh yeah its an mv6, not sure if that makes any difference, thanks
lee
Re: windscreen wipers
« Reply #1 on: 06 May 2010, 05:31:24 »
http://www.omegaowners.com/forum/YaBB.pl?num=1259003779
A lot of very usefull information in the guides section.
Just had a quick nosy through nut cant find anything on the relays.
There have been pics of the relays/;ocation and fuses etc, but I just cant remember where they were posted, someone may be able to help later.
Did you get a hand book with your car, loads od usefull info in it, including fuses/relays.
Fuse box/mayme some relays are in a panel under the steering whhl.
Other relays etc are in the trianular box over the battery.
Just be carefull, as yours ahas had a heart transplant it may well have had a lot of rewiring done.
flossbag1
« Reply #2 on: 07 May 2010, 02:02:15 »
Wicked buddy thanks for that, will have to try and locate the manual, not sure where that is, could be amongst the rest of the junk in the garage. Your also right about the wiring, dont know where to start there, i reckon my hammster's got more of a chance of finding whats what, thanks  :)
lee
« Reply #3 on: 07 May 2010, 12:18:06 »
check you dont have rain sensing wipers - that replaced intermittent setting on some later cars
