Author Topic: Removing MAF connector ......  (Read 1637 times)
I_want_an_Omega
« on: 07 May 2010, 19:35:51 »
I'm struggling to remove my MAF connector - it just wont budge.
Thing is I'm not sure whether I should be squeezing the tab down towards the back (i.e toward the wring loom), or toward the MAF itself.
I've tried both and rocking from side to side with no avail.
Any ideas?
Thanks
Welung666
Re: Removing MAF connector ......
« Reply #1 on: 07 May 2010, 20:08:57 »
You're not having much luck with electrical connectors are you? ;D ;D
Squeeze the ribbed bit ;) They can be tight so I normally, while holding the ribbed part down, push the connector together and the other end will pop up then just pull ;)
I_want_an_Omega
« Reply #2 on: 07 May 2010, 21:28:17 »
ta
Page created in 0.01 seconds with 18 queries.
