Author Topic: Flashing alarm LED  (Read 6455 times)
Ploppy
  • Norfolk
Flashing alarm LED
« on: 08 May 2010, 11:33:42 »
Hi all....
help needed please  ....
I wish to fit a flashing LED light to my facelift 2003 omega.... so to deter those naughty people ...
has anyone fitted one and where is the best place to fit one and where to get the best power source ???
Ie you remove the keys and it starts flashing???
Regards Ploppy :o
    • 530D M Sport, 330i Coupe
Re: Flashing alarm LED
« Reply #1 on: 08 May 2010, 11:44:27 »
I would buy the original alarm switch and wire it up behind the dash to illuminate the LED
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #2 on: 08 May 2010, 11:46:28 »
Me too as most peolple know what they look like anyway. Anything else may look trashy
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 08 May 2010, 12:32:30 »
Look for a standard RED flashing LED, as that is what the alarm guys use mostly, they seldom use green, blue or any other colours, so if you want it to look like an alarm, keep it simple.
You can buy a 12V flashing LED for a couple of quid, and make sure that you fit it somewhere near the stereo or dash panel, as these are generally the first places people glance inside, and also where the alarms fitters choose to locate them.
http://cgi.ebay.co.uk/Car-Caravan-Marine-Alarm-Flashing-Blinking-LED-12v-RED-/270546487264?cmd=ViewItem&pt=UK_Campervan_Caravan_Accessories&hash=item3efdd3c7e0
Your LED will probably have a red and a black wire.
Connect the red wire to a supply that is permanently live, and connect the black wire to a supply that is only live when the ignition is switched on, and that way when the keys are taken out the LED will start to flash.
Ignition and permanent feeds can be found at the rear of the stereo amongst other places
Hope this helps
« Last Edit: 08 May 2010, 12:37:24 by Dave_DND »
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #4 on: 08 May 2010, 13:53:52 »
Looking at the link Dave posted they are what CPC/Farnell sell for .99p
Maplins may also sell them.
Ploppy
  • Norfolk
« Reply #5 on: 08 May 2010, 18:47:18 »
Thanks Dave
yes that s what I have,,
is there a feed near the sunroof/ light area I could get a feed from and what would the wires be ??
Thanks and regards to all ...
Ploppy  :y
Ploppy
  • Norfolk
« Reply #6 on: 09 May 2010, 22:52:39 »
Anybody know? :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 10 May 2010, 09:04:54 »
Thanks Dave
Ploppy  :y
Putting an LED up there would not look like a professional fit and would defeat the whole point of doing it.
kevyn
  • hertfordshire
« Reply #8 on: 10 May 2010, 10:37:34 »
done this one myself and it's a tricky bugger :) doable, but patience is required  ;D
the 'earth' of the led is on the botton pin of the relay. It's the only one i could test that works. live when on, earth when off etc.
« Last Edit: 10 May 2010, 10:41:43 by kevyn65 »
kevyn
  • hertfordshire
« Reply #9 on: 10 May 2010, 10:40:40 »
« Last Edit: 10 May 2010, 10:42:24 by kevyn65 »
Ploppy
  • Norfolk
« Reply #10 on: 10 May 2010, 12:16:04 »
Kevyn,
thanks for that info....
thats great...
yes it does look better down there...Dave... :y
Where abouts in the vehicle are the relay as in your picture...
Thanks
Ploppy :y
« Reply #11 on: 10 May 2010, 12:36:03 »
Where abouts in the vehicle are the relay as in your picture........
It's under the steering column, you can see part of the diagnostic socket  ;)
kevyn
  • hertfordshire
« Reply #12 on: 10 May 2010, 14:30:46 »
Take the ashtray out and route the wires behind and up the steering colum. fiddly but easy.
I've got loads of flashing blue/red alarm LED's if anyone wants one. PM an address and i'll post one to you free. They look the nuts and are realy bright. (it was cheaper to buy in bulk)  ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #13 on: 10 May 2010, 14:45:59 »
But MEGA BRIGHT ones are not used in the alarm world !!
Are you simply after a flashing light, or something that looks like a genuine alarm?
Both wires required are at the rear of the stereo - dead easy run !!
« Last Edit: 10 May 2010, 14:46:52 by Dave_DND »
Ploppy
  • Norfolk
« Reply #14 on: 10 May 2010, 15:41:17 »
Hi,,,,Dave
already have the LED,,
just need to know what wires to connect on stereo wires please
Regards
Ploppy :y
