Author Topic: Facelift instrument panel removal and bulbs  (Read 4601 times)
Raymond
  • Glasgow
« on: 11 May 2010, 19:49:38 »
I have noticed that a couple of my instrument panel bulbs have gone. Can anyone advise what kind of bulb to use? Are the high power led's any good for this? and is removal of the panel the same as the prefacelift?
Thanks in anticipation!
Re: Facelift instrument panel removal and bulbs
« Reply #1 on: 11 May 2010, 20:03:49 »
Guide in maint guides section.
LEDs don't work well
« Reply #2 on: 11 May 2010, 20:05:11 »
501 capless. Ideally 3W
Raymond
  • Glasgow
« Reply #3 on: 11 May 2010, 20:22:10 »
Thanks guys, I saw the removal guide, cheers for that. So do I just buy the bulbs or do I need the bases for them as well?
Once again thanks for the info
Raymond
  • Glasgow
« Reply #4 on: 11 May 2010, 20:22:53 »
Sorry forgot to ask how many bulbs there are, and are they all white?
« Reply #5 on: 11 May 2010, 20:25:49 »
4 bulbs, all clear. You just need the bulbs, they pull out of the base
« Last Edit: 11 May 2010, 20:27:06 by RobG »
Raymond
  • Glasgow
« Reply #6 on: 11 May 2010, 20:27:28 »
Cheers once again but how does only 4 bulbs light up all the different lights, i.e. engine management, oil pressure, dipped lights etc.
« Reply #7 on: 11 May 2010, 20:29:09 »
What actual bulbs are blown. I assumed you meant the main illumination bulbs :question
« Reply #8 on: 11 May 2010, 20:30:46 »
It's four lamps for the back light illumination.
Each warning lamp has its own bulb/lamp! (not all spaces have a lamp ie seatbelt & over temp cats)
Raymond
  • Glasgow
« Reply #9 on: 11 May 2010, 20:31:08 »
Sorry my fault, its the dipped headlight bulb and another I cant remember at the moment but if I am in there I might as well change them all.
« Reply #10 on: 11 May 2010, 20:32:59 »
Warning lamps are soldered into their holders. Orange bases are 1.2w others are 2.0w
« Reply #11 on: 11 May 2010, 20:33:10 »
Dipped head light? :-? There's a blue main beam ......  :-/  :-/  :-/
« Reply #12 on: 11 May 2010, 20:34:17 »
I think that`s what the OP means Andy :)
« Reply #13 on: 11 May 2010, 20:36:13 »
Dipped .... main ..... same thing really  ::)  ::)  ::)  ::) I hope I'm not travelling towards him!  ;)  ;)  ;)
page 12  :y
Raymond
  • Glasgow
« Reply #14 on: 11 May 2010, 20:36:31 »
Are the warning lamps a differnt kind of bulb?
Is there not a green dipped headlight one in the cluster? Maybe thats why I can't find it/thought the bulb had blown. My information display is very dull as well, do these have replaceable bulbs?
