Author Topic: Bad reception  (Read 1903 times)
shaggydog
  • flintshire
Bad reception
« on: 14 May 2010, 16:10:18 »
Hi i've got a ccr2006 and the reception is lousy, I can barely pick up local radio stations. Any help thanks >:(
Welung666
Re: Bad reception
« Reply #1 on: 14 May 2010, 16:11:54 »
Is the roof ariel still there?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bad reception
« Reply #2 on: 14 May 2010, 16:17:48 »
Check the angled aerial connector at the rear of the radio - centre core is prone to fracture
Also, if you have a screen aerial, worth checking the joints from aerial booster to screen
If you have an external aerial, check that the internal amp in the base has not got water damaged.
Radio & Decoding Technician
www.dndservices.co.uk
shaggydog
  • flintshire
Re: Bad reception
« Reply #3 on: 14 May 2010, 16:30:59 »
will do when it stops raining thanks :)
