Author Topic: Remote Central Locking Fob  (Read 3213 times)
goose
  • Exeter
    • 2.6L V6
    • Paul D Smart Photography
« on: 04 May 2010, 22:51:31 »
Hi Everyone...
So my Omega has a key and a remote central locking key fob (two button). When I bought the car, the owner said the battery would need changing. It did need it and I did change it.
However, push the button (either of them), and nothing happens (other than the lights flashing on the fob).
Any ideas?
Re: Remote Central Locking Fob
« Reply #1 on: 05 May 2010, 00:00:07 »
Hi Everyone...
Any ideas?
it needs re-syncronising. Key in, ign on & press lock, doors lock and then unlock!  :y Done!  :y
goose
  • Exeter
    • 2.6L V6
« Reply #2 on: 10 May 2010, 09:09:40 »
Sorry for long reply... been working like a mad man last week or so!!!
Thank you very much!
Well, that certainly does work... though I think the actual buttons are a bit dodgy as sometimes the light comes on and the door opens/locks and sometimes it doesnt.
If i resync the two again it works fine then it goes again. Strangeness!!!
« Reply #3 on: 10 May 2010, 09:36:40 »
Sounds like the battery connection on the pcb inside is iffy. Martin Imber here on the forum has fixed loads for a reasonable fee.
PM him ..... I'm sure he'd be able to sort yours out  :y
« Reply #4 on: 10 May 2010, 09:41:02 »
1996 car will be seperate fob, don't normally suffer from broken battery holder ime...
« Reply #5 on: 10 May 2010, 09:43:38 »
Didn't realise ...... the re-sync worked though  :-/
« Reply #6 on: 10 May 2010, 09:44:51 »
I agree, my initial reaction would be batt holder soldering, but on those, possibly worth checking for poor contacts on holder, or even a duff battery.
goose
  • Exeter
    • 2.6L V6
« Reply #7 on: 10 May 2010, 10:34:30 »
Cool Thanks!
Will check the connections and report back.
Battery is fine as have checked that and replaced it and checked the replacement too... :D
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #8 on: 13 May 2010, 22:39:06 »
Hi,
I have a similar problem in as much as when I use the fob all doors lock except the Drivers door. I opened the door and the alarm sounded. I can lock the door with the key. I only bought the car today and have no manual. Any ideas please ???
« Reply #9 on: 13 May 2010, 22:39:56 »
knackered cdl....
« Reply #10 on: 13 May 2010, 22:44:05 »
Hi,
Solenoid/motor in the door is u/s. Not too difficult to replace, just fiddly.  ;)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #11 on: 13 May 2010, 23:04:31 »
Thanks for the quick reply...most appreciated
goose
  • Exeter
    • 2.6L V6
« Reply #12 on: 14 May 2010, 17:30:08 »
problem solved - its the battery holder part!!!
If i "squeeze" the fob and press the button it works a charm :) yay!
Will get it sorted properly shortly. Thanks for everyones comments :)
shaggydog
  • flintshire
« Reply #13 on: 14 May 2010, 17:43:47 »
Had the same problem put a bit of blue tac on a piece of paper on top of the battery works fine now.  :)
Martin_1962
« Reply #14 on: 14 May 2010, 19:40:16 »
I repair the battery holders, PM me for details
