Author Topic: Few things stopped working  (Read 2364 times)
BobIsHere
  • Midlands
« on: 10 May 2010, 22:37:52 »
Kind of sorted my radio out but now my sunroof and heated seats are not working? are they on the same fuse???
Re: Few things stopped working
« Reply #1 on: 10 May 2010, 23:49:49 »
Think so, I had an issue with my heated seat when I bought it and when the fuse blew so did a couple of other things.
Not sure if it was fuse No17
(Jimbob, is there any chance of a fuse and relay layout for the cars in the guides sections, maybe info on capaciries, wheels/tyres siazes and pressures etc - Just a thought as I reckon a lot of members might find it helpfull)
« Reply #2 on: 11 May 2010, 02:10:17 »
Already here - http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
and here - http://www.omegaowners.com/forum/YaBB.pl?num=1161602010
« Last Edit: 11 May 2010, 02:11:42 by dbug »
BobIsHere
  • Midlands
« Reply #3 on: 12 May 2010, 09:23:48 »
plot thickens, opened the fuse box, sunroof fuse had blown changed it still no sunroof movement, the seat is on the same fuse as other things that are still working??  beginning to go off the omega.. Wish i had left the radio alone now.. :-[
Jezzer
  • Herts
« Reply #4 on: 15 May 2010, 18:01:34 »
Had a similar problem with a dodgy radio set up, changed for a SONY MP3 CD, but had most electrical items go, and the fuse hadn't gone!
I disconnected the battery earth, pressed footbrake to drain remaining power, reconnected battery.
Heated seats worked OK after that?
On sunroof, I found that you had to press and hold the rotary switch for about 5-7 secs and it worked manually in all positions, after that worked on auto and been fine since  :)
All other items started working then, e.g. Cruise, Computer, Info Display Panel, (inc. smaller icons in the Centre) e.g. dolby, cassette, cd) Also auto up and down on all windows stopped, also OK... weird  :o
May not work - but worth a try, but remember that after 10 secs the alarm may go off and you will lose any stored Radio stations
Jezzer
« Reply #5 on: 15 May 2010, 18:10:51 »
what remaining power from where? Pressing the brake has just released what ever vacuum you had.  ;)
On sunroof, I found that you had to press and hold the rotary switch for about 5-7 secs and it worked manually in all positions, after that worked on auto and been fine since  :) ......
Like it says in the manual   ::)  ::)  :y  :y  :y
