Author Topic: manual conversion wiring  (Read 2991 times)
mv6 omega
« on: 11 May 2010, 17:19:58 »
hey there, new to the site. Ive just finished doing the manual conversion but now i get the automatic transmission error on mid. how do i get rid? ive read of earthing out a wire to change it to manual on mid but dont know what wires to do?
Car is currently sorned so cant get it to a tech2.
can anyone tell me what wires need sorting out plz?
great site btw
ed
Welung666
Re: manual conversion wiring
« Reply #1 on: 11 May 2010, 18:37:43 »
Hi Ed, welcome aboard :y
Have a read of [size=16]THIS[/size][/b][/url] :y
mv6 omega
« Reply #2 on: 11 May 2010, 21:01:20 »
Thanks Welung666 ive already read the guide, i'm needing help on the automatic transmission error.
Ed
Welung666
« Reply #3 on: 11 May 2010, 21:27:23 »
;D I misread your original post  :-[
Is your TID the grey connector?
mv6 omega
« Reply #4 on: 12 May 2010, 19:02:13 »
Yeah its the grey plug.
Welung666
« Reply #5 on: 12 May 2010, 20:52:03 »
Pin 21, grey wire goes to the auto transmission :y
mv6 omega
« Reply #6 on: 12 May 2010, 21:28:57 »
Excellent, do i just chop the wire and then put the plug end of the wire to an earth point? taping up the other end frorm the loom.
Welung666
« Reply #7 on: 12 May 2010, 21:53:14 »
IIRC yes but put a low blow fuse, such as a 3 amp, inline just in case. If it survives and clears the message then you should be OK without the fuse :y
mv6 omega
« Reply #8 on: 12 May 2010, 22:25:28 »
Thanks for the help. ill give it a go tomorow
Ed
gsizoli
  • Hungary
« Reply #9 on: 16 May 2010, 14:16:37 »
I've also made the conversion on my 3litre, you have to go to TECH2 programming, to dissolve the automatic transmission message on your screen. In the ABS menu must set up that your car is manual, furthermore in the dispaly menu too (as i remember well).
