Author Topic: Plugs on ABS  (Read 1716 times)
splott
  • Bebington, The Wirral
  • Veccy with a Miggy engine..............
    • Vectra GSI 3.2 v6
Plugs on ABS
« on: 17 May 2010, 17:04:48 »
On the ABS ecu are two plugs, one is a two pin and the other is a multi core plug.
Question is do these plugs pull straight out or is there a catch or something that has to be released. The multi plug is tight!
Thank you for reading this. I’ve officially wasted your time!
Re: Plugs on ABS
« Reply #1 on: 17 May 2010, 17:57:22 »
Multi-plug on top has a retaining clip that slides towards the passenger wing. Still quite tricky though. Bottom plug has standard plastic sprung clip
« Last Edit: 17 May 2010, 17:59:01 by RobG »
splott
    • Vectra GSI 3.2 v6
Re: Plugs on ABS
« Reply #2 on: 17 May 2010, 18:18:12 »
Thanks for the info :y
I have got the twin one off but struggling with the multi plug. It just will not slide :'(
Thanks again :y
splott
    • Vectra GSI 3.2 v6
Re: Plugs on ABS
« Reply #3 on: 17 May 2010, 18:25:27 »
Thanks again :y
RobG your a saviour, sorted. Thanks :y
