Author Topic: CCR2006 removal  (Read 4095 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
CCR2006 removal
« on: 24 May 2010, 17:22:04 »
I have removed the grub screws, inserted the two Vx removal tools, poked my fingers into the magazine and tape holes and pulled.
The bugger won't move. Just feels like the front will fall off :-?
Am I missing something  :-/ :-/
The happiest people don't have the best of everything,
they just make the best of everything they have.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2006 removal
« Reply #1 on: 24 May 2010, 17:25:36 »
Exceptionally tight in the mounting frame - just be carefull when pulling with your feet on the dashboard (yes its that tight) that you do not pull the fascia off.
Radio & Decoding Technician
www.dndservices.co.uk
Tonka.
    • 2000 2.5 CDX
Re: CCR2006 removal
« Reply #2 on: 24 May 2010, 17:30:02 »
Really  :o :o
I can see myself blacking both eyes and loosing teeth, never mine pulling the fascia off  ;D ;D
Re: CCR2006 removal
« Reply #3 on: 24 May 2010, 18:46:15 »
Easiest way I`ve found is to insert the double dins then pushing them towards the doors and wiggling the unit side to side, eventually it does release from the cage albeit one side at a time
Re: CCR2006 removal
« Reply #4 on: 24 May 2010, 18:55:13 »
Really  :o :o
 ;D ;D ;D ;D ;D ;D that task used to be so easy on the cars of twenty years ago!! ::) ::) :D :D
A time to curse the designers (again!!)? :D :D ;)
Re: CCR2006 removal
« Reply #5 on: 24 May 2010, 19:18:43 »
Make sure that your fingers are pulling on the metal chassis behind the fascia, not the fascia itself.
They are tight but the "finger in each slot" technique worked for me.
Tonka.
    • 2000 2.5 CDX
Re: CCR2006 removal
« Reply #6 on: 24 May 2010, 21:01:02 »
Finally got the blighter out. Got my fingers stuck at one point. But out she came.
Kept all of my teeth as well  ;D ;D
Thanks all  :y :y :y :y
    • 530D M Sport, 330i Coupe
Re: CCR2006 removal
« Reply #7 on: 24 May 2010, 21:25:36 »
Fun job isn't it!!
MickAP
  • South Derbyshire
Re: CCR2006 removal
« Reply #8 on: 24 May 2010, 21:42:47 »
I tried twice with mine and gave up f@@kin thing! >:(
Mick :D
