Author Topic: Speedo and rev counter not working  (Read 1825 times)
mrb
« on: 24 May 2010, 17:19:37 »
Hi there - anyone come across this problem before?  Speedo and rev counter both go off together on my 1999 2.5v6 cdx.  Happened intermitently during winter then ok - now both off completely, with speedo needle vibrating madly at zero! had it on tech2 at local independant vauxhall specialist when first happened but with no joy.  No warning lights on and ABS and steering all working fine :-?
Re: Speedo and rev counter not working
« Reply #1 on: 25 May 2010, 10:32:49 »
well good news if ABS is working its not the ABS ECU which is common failure for speedo, but as its that and the rev counter, check the dash is fully pushed back. Also check fuses  :y
« Last Edit: 25 May 2010, 10:33:00 by tunnie »
