Author Topic: Ccrt700 no radio signal  (Read 2094 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 25 May 2010, 17:22:57 »
Hi my new ratio is all put in but I can fond a radio signal anywhere out of a town,usually can!as soon as leave town it goes and just scans all the time.aireal is all connected ag back of stereo so any clues guys?
scream if you want to go faster!!!
Re: Ccrt700 no radio signal
« Reply #1 on: 25 May 2010, 18:43:33 »
Connections to amplifier/heated rear screen OK?
mr ICE man
  • dolgellau wales
« Reply #2 on: 25 May 2010, 18:49:22 »
Screen works fine yeh where is the amp?
« Reply #3 on: 25 May 2010, 19:27:36 »
Screen works fine? You mean as a demister? It's also your radio aerial  ;), the amp is under the parcel shelf cover.  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 26 May 2010, 09:00:06 »
Also check angled connector at back of radio, centre core fractures very easily
Radio & Decoding Technician
www.dndservices.co.uk
mr ICE man
  • dolgellau wales
« Reply #5 on: 26 May 2010, 19:02:13 »
I had a closer inspection today and it looks like at some point the rear screen has been replaced.would this make a difference?
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #6 on: 27 May 2010, 01:34:42 »
check on the plug in the left side light cover should be a plug upto the right pull off it clip, there you should find a 6 pin plug check the wires on that as gose to arial amp, black and purple should be live with engine light on (engine key number 2)( off no volts) if not then the radio is not sending volts to the amp. when radio is pluged in even switched off sends volts but when removed there is no volts.
Page created in 0.022 seconds with 20 queries.
