Author Topic: fitting amp and sub  (Read 5961 times)
russ b
  • dudley west midlands
fitting amp and sub
« on: 24 May 2010, 11:31:30 »
hi, simple enough i imagine. have got after market jvc head and know got sub enclosure in boot. i need to buy amp but on checking rear of head there is't any extra outputs just wiring into loom.i figureif i get cdr500 in car there isoutputs needed for amp. im sure this is simple but i never done this before any advise on fitting amp and sub and does cdr500 havewhat i need...help an amateur  :'(
Re: fitting amp and sub
« Reply #1 on: 24 May 2010, 11:36:06 »
Better off just changing the headunit and speakers.  Subs not really required, unless your other car is a Corsa....
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #2 on: 24 May 2010, 11:38:45 »
i think you will find it easer to get another after market head unit as even if the cdr500 has amp outs ( they will be for a bose amp so no good anyway ) you wont have the wiring in your car to get the feeds to the amp anyway . so i think you will be better off with new head unit and run your own cables to the amp . sorry for bursting your bubble  :-/
2001 MV6 3.2 manual been converted from 2.6 auto
russ b
« Reply #3 on: 24 May 2010, 11:39:05 »
fair point, new job means i'm doing about seven hundred mile a week know and the stereo quality has suddenly jumped up the priority list. thought mr osbourne would sound better with stereo upgrade ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 24 May 2010, 11:41:54 »
That is so wrong !!
A sub can make a hell of a lot of difference to the sound by adding a little warmth and some lower frequencies. Do not categorise those wanting to improve the sound with the chavs who go over the top giving bass at the expense of everything else.
Not sure what amp you have, but if it does not have high level inputs that can be connected to the rear speakers, try one of these which are suitable for the high power output of your JVC head unit
http://www.dndservices.co.uk/px042.html
Radio & Decoding Technician
« Reply #5 on: 24 May 2010, 11:43:09 »
cdr500 isn't bose compatible either.  Its just generally and all-round naff HU, with nothing going for it.  It plays audio CDs, a below-par radio, and poor output stage.  Yet they fetch good money on egay - nearly bought a load of them yesterday to stick on ebay ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 24 May 2010, 11:44:40 »
In fact this may also be worth a look as it has speaker inputs built in, and at the bottom of the link is the sub that is designed to go with it
http://www.dndservices.co.uk/apx2121e.html
bigtow
  • rochester kent
« Reply #7 on: 24 May 2010, 11:45:45 »
 i bow to your knolage of such matters . it could be worse it could be sony ............ sorry for using that word but
russ b
« Reply #8 on: 24 May 2010, 11:46:53 »
well that was why i thought they where good head unit they fetching some silly money on e-bay. :o
« Reply #9 on: 24 May 2010, 11:50:27 »
That is so wrong !!
Maybe you misunderstood me :P
Replacing HU and changing the existing speakers would be more worthwhile than messing around with cdr500, trying to get a modest amp working, retaining existing Vauxhall speakers, and shoving in subs to overcome defficiencies of the Vauxhall speakers.
That is what I would do if it wasn't for me being so anal about retaining some kind of GM look  :-[
Beyond that, yes, there is another step up of better amps and fitting subs to bring extra life to the music (and lets not forget higher frequencies either - though quality speakers go a long way to help here already imho (maybe because I'm tone deaf!!)).
I suspect from the original post that the OP wanted to do this on a tightish budget, so I maintain that a better HU with quality speakers would be the better way to spend limited cash....
...unless his other car is a Corsa, and sound quality doesn't matter as much as the db pumped out by an overbassed sub ::)
« Last Edit: 24 May 2010, 11:52:16 by TheBoy »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 24 May 2010, 11:55:46 »
CDR500`s are indeed fetching silliy money at the moment. There is a definate trend at the moment to going back to OEM head units, probably because most of the CD players available at the moment are all around the £50 mark and are absolute crap - only other ones are the chinese fleabay monitor stuff and they are no better. So many people have now been financially stung by this junk that they are now going back to the original models as they know they are good.
A lot of the brands are building cheap stuff now under customer pressure, Kenwood, Pioneer etc, it isn`t what it was, Blaupunkt was recently sold off by Bosch who wanted to distance itself from what was once a quality brand, and Sony are pulling out of In Car shortly.
Clarion are still one of the good brands and have never compromised their build quailty to become financially appealing. Pay a premium, get a quality unit
russ b
« Reply #11 on: 24 May 2010, 12:16:12 »
correct about budget.... already had a sub though so really just trying the best setup with what i got and what i can afford
i have never installed a sub and amp before so don't know whats involved all suggestions welcome as my knowledge is carp :-[ got to go to travel halfway round the world know will catch up on post when i get back round 1 in morning :'( :'( thabks for the help guys
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 24 May 2010, 12:30:09 »
My bad - should have quoted part of the message  :-[
It was the sub bit I was in disagreement with - subs always worth installing.
But change of speakers (with or without amp) are essential, (even if retaining the original head unit) as those paper cone things are rubbish
Welung666
« Reply #13 on: 24 May 2010, 12:36:52 »
I can help you fit it Russ, done a few in my time ;)
russ b
« Reply #14 on: 25 May 2010, 01:22:07 »
cheers lee, i got fri off can meet you at 5:30 same old same.
aren't you sick of the sight of me yet?
show you what i got and you tell me what you think!! ;D
im assuming you drink or smoke i'm sure i owe you by know name your brand 8-) 8-)
