Author Topic: CAN bus/Mutiplex vehicles  (Read 2527 times)
miggy
« on: 28 May 2010, 20:55:49 »
Could any of you guys tell me if the 2003 Omega uses the CAN bus/Multiplex system on the lighting wiring, i have a Valeo automatic lights on/off kit and it says that the dash lights may not come on if on the above system when the lights come on automatically.
It also gives you 3 wiring diagrams, 2 are for Positive wiring and 1 is for negative wiring, the latter is more complicated, any advice on which i should follow, positive or negative, this stumped me a bit.:-/
« Last Edit: 28 May 2010, 20:59:31 by miggy »
Re: CAN bus/Mutiplex vehicles
« Reply #1 on: 28 May 2010, 21:04:40 »
Think it`s only these, Corsa D all use canbus
Astra H all use canbus
Zafira B all use canbus
Vectra C 02-04 use half canbus,all05 on use full canbus
Signum A 02-04 use half canbus,all 05 on use full canbus
Meriva upto 04 half canbus,all 05 on use full canbus
  • Auckland
    • Mazda MPV
« Reply #2 on: 28 May 2010, 22:01:12 »
AFAIK the Omega is CANBUS free (with one exception).
The exception being the link between an NCDC head unit and its graphics display. A little extra loom that only connects the screen and head unit and doesn't talk to any other component in the car...
« Reply #3 on: 28 May 2010, 22:16:55 »
Hmmm.  Omega is not classed as CAN, but there are a couple of CAN systems onboard (though not a proper implementation).
The chatter between engine and gearbox is a form of CAN.
The protocol between CCRT and NCDC ICE units, and their displays and CD Changers is CAN
Dany
  • Belgium
« Reply #4 on: 28 May 2010, 22:34:32 »
I HAVE an Omega 2003 and I HAVE a Valeo automatic lights on/off installed on it and all work perfectly, no CAN bus present on the lighting wiring, don't worry ;)
« Last Edit: 28 May 2010, 22:36:30 by moudufond »
miggy
« Reply #5 on: 29 May 2010, 10:51:56 »
Thanks for the info chaps,
Dany thanks for the full wiring installation, my french is not too good but i had it translated via google.
Dany
  • Belgium
« Reply #6 on: 29 May 2010, 17:14:02 »
No problem mate, If you need more help, just ask  :y
