Author Topic: sunroof fuse?  (Read 1699 times)
omegod
  • liverpool
    • 2017 Seat Ateca
sunroof fuse?
« on: 31 May 2010, 20:12:54 »
After cleaning the magnetic disc it's still playing silly buggers, does it have it's own fuse that can be pulled?
Re: sunroof fuse?
« Reply #1 on: 31 May 2010, 20:18:06 »
#25
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: sunroof fuse?
« Reply #2 on: 31 May 2010, 20:20:51 »
what is it doing??? did you re-magnetise the disc as they can lose there magnetism, just leave on a magnet for an hour or so.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: sunroof fuse?
« Reply #3 on: 31 May 2010, 20:23:56 »
The old open and close all by itself trick, I stuck it to the back of a speaker for a couple of hours to no avail.
same #same#
  • south yorks
Re: sunroof fuse?
« Reply #4 on: 31 May 2010, 20:28:18 »
has it got wet at some point as it triggers the auto open, you can read the unit on tec2 to see what the fault is and wipe it as they dont wipe them self,, tec2 can fix it if it can still be read.p.s will keep opening and closing until it is wiped.
« Last Edit: 31 May 2010, 20:29:29 by Russ76 »
