Author Topic: NCDC 2013  (Read 5055 times)
nell77
  • manchester
NCDC 2013
« on: 01 June 2010, 23:00:12 »
Just breaking an elite with this in and looking at it does it have sat nav? What kind of money do they bring are they any good? Do they fit in vectra`s?
hotel21
  • The Kingdom of Fife
Re: NCDC 2013
« Reply #1 on: 01 June 2010, 23:05:08 »
Remember its not as simple as removing the radio from the car and selling on.  It needs depairing with tech2 first, as does the screen.
If you dont, its simply a doorstop.
moving to the ICE section.   ;)
nell77
  • manchester
Re: NCDC 2013
« Reply #2 on: 01 June 2010, 23:09:25 »
cheers.
But if they sell together screen and stereo as a pair would it then work?
hotel21
Re: NCDC 2013
« Reply #3 on: 01 June 2010, 23:18:57 »
cheers.
No.
Both need to be returned to factory mode, individually, otherwise each as good as a chocolate fireguard....
nell77
  • manchester
Re: NCDC 2013
« Reply #4 on: 01 June 2010, 23:33:46 »
so these are worthless really
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013
« Reply #5 on: 01 June 2010, 23:34:58 »
If you have removed them without de-pairing, then yes !!  Worthless !!
Depaired? Thats another matter, they can fetch good money
Radio & Decoding Technician
www.dndservices.co.uk
nell77
  • manchester
Re: NCDC 2013
« Reply #6 on: 01 June 2010, 23:40:33 »
and how do you de-pair?
hotel21
Re: NCDC 2013
« Reply #7 on: 01 June 2010, 23:45:45 »
You require a genuine VX Tech2 device, coupled to the original car and a carpass so that they can be depaired/placed into delivery mode, prior to removal.
If already removed from the car, needs to be replaced in the vehicle they came from then depaired, if you follow....
As Dave says, if done properly, worth good coin.  If not, worthless other than limited use for parts....
« Last Edit: 01 June 2010, 23:46:36 by hotel21 »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013
« Reply #8 on: 01 June 2010, 23:50:11 »
Depairing is the reverse of entering a security code.
This particular model needs a "code" to be entered (via a Tech2 programmer) so that it is electronically de-programmed from your car. When de-programmed/divorced/depaired it is then in a state often referred to as "delivery mode" which means that it can then be programmed to another car, again by Tech2.
A radio can only be programmed to a new car if depaired first, and it cannot be depaired outside of the original car any other way.
hope this helps
« Last Edit: 01 June 2010, 23:50:49 by Dave_DND »
Re: NCDC 2013
« Reply #9 on: 02 June 2010, 19:20:47 »
To clarify - if *ALL* the components in the NCDC setup are kept together (NCDC201x, CD Changer, Display, Screen), then you do *NOT* need to depair.
This info is specific to the Omega.
This setup will *NOT* work in the Vectra-C. The screen is very different. The headunit can be used on Vectra-C but will need to be depaired, then repaired to a suitable Vectra-C screen.
hotel21
Re: NCDC 2013
« Reply #10 on: 02 June 2010, 19:36:37 »
I sit corrected.   :y
If you subsequently need to split the bits from each other then do you need the original pass or the one from the Omega its in now??
Re: NCDC 2013
« Reply #11 on: 02 June 2010, 20:25:25 »
I sit corrected.   :y
You need the original code that it was paired with...
Re: NCDC 2013
« Reply #12 on: 02 June 2010, 21:49:38 »
interesting, must admit i thought it would be fine if just screen and hu where removed and refitted in another omega. Needs all components as a set then?
But 2013 has changer built in and no phone thing (telematics?) in glove box, so hu and screen is all there is in this case...... just wack it/em in?
Re: NCDC 2013
« Reply #13 on: 02 June 2010, 22:25:54 »
For a 2013, the HU (complete with CD Changer - that is part of the security loop) and the screen.  For a 2015, the HU (with CD Changer), screen and telematics.
