Author Topic: Fitting cruise to the plod  (Read 1819 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 02 June 2010, 19:38:03 »
OK this is how far i have got. TB did his magic with the Tec2 for me and I have looked and the wiring is there to plug up to the control lever which will be here on saturday. Have just looked to see were to put clutch switch (which sould also be here saturday) i did not know I could still get into that part of the car at my age. only thing is what connection does the switch fit into, I can see one under there with a white connector is that it? :-?
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Fitting cruise to the plod
« Reply #2 on: 03 June 2010, 13:10:57 »
Thanks Rob thats another little job for Saturday :y :y
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #3 on: 16 April 2012, 22:15:29 »
my 2001 mv6 has been converted from auto to manual i have fitted a new 4 pin brake pedal switch and have got a clutch switch but cant find the plug for the clutch switch any pointers or clues if my car will have it or will i need to modify the wiring if so what wires will i need to splice into ?
2001 MV6 3.2 manual been converted from 2.6 auto
