Author Topic: Dead battery  (Read 4121 times)
cmeonthemove
  • Taverham, Norwich
Dead battery
« on: 03 June 2010, 19:03:04 »
Come out from work tonight to find a dead battery (dim warning lights and no action from starter) so taking the battery to be dead. Is there a quick guide on here to putting a new one in so I know which tools I'll need to take on the bus tomorrow? Not changed one myself before.
Zero marks from Tesco Breakdown who seem to have 'forgotten' about my phone call to renew in October, as a result no cover  >:(. Just as well they didn't charge me for it.
« Last Edit: 03 June 2010, 19:03:35 by cmeonthemove »
Chris
2.5 Elite
Re: Dead battery
« Reply #1 on: 03 June 2010, 20:16:17 »
10mm spanner for the battery terminals. 13 mm socket on an extension long enough to get down the side of the battery to the clamp. BAttery needs to be disconnected within 15 seconds of turning the ignition off, otherwise the alarm will (should  ::)) sound  :y
Page 61  :y http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
« Last Edit: 03 June 2010, 20:17:54 by Andy_B »
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Dead battery
« Reply #2 on: 04 June 2010, 00:22:49 »
did you leave the lights on or somthing as it just may need a charge up, or somthing is draining the battery?? also is the alternator working properly. have you had battery light come on at any time.
cmeonthemove
  • Taverham, Norwich
Re: Dead battery
« Reply #3 on: 04 June 2010, 04:03:25 »
No everything was fine on the drive to work, no lights in the dash or any signs the battery not charging. I'm guessing the battery as it wouldn't respond to jump leads. I'll get a new one today and see what happens. I had something very similar happen several years ago on a Neon and that was the battery too.
Thanks for the guide Andy. :y
Chris
2.5 Elite
same #same#
  • south yorks
Re: Dead battery
« Reply #4 on: 04 June 2010, 06:40:05 »
bit funny not jump start with leads, should start that way even with a dead battery even dead cells. are you sure its not the starter motor??
Aicis
Re: Dead battery
« Reply #5 on: 04 June 2010, 10:37:41 »
Happened to me to.
Tried 3 different jump leads and 2 other cars to to jump start from.
Was afraid of it being the starter, but the service guys somehow started it and confirmed it was a battery.
Be sure to get the battery with correct fittings - it has a little grip area at the bottom of it ->
cmeonthemove
  • Taverham, Norwich
Re: Dead battery
« Reply #6 on: 04 June 2010, 13:47:12 »
The Elite lives again  :) :) :). New battery, started first time. I'm going to get a voltmeter after work so I can check all the polarities and currents to make sure it's not draining and the alternator is charging it, but at the moment it looks like the battery after all.
Cheers again guys  :y
« Last Edit: 04 June 2010, 13:48:33 by cmeonthemove »
Chris
2.5 Elite
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Dead battery
« Reply #7 on: 04 June 2010, 14:59:50 »
Might be worth slow charging the old battery for a few days then leaving it alone for a few more days before testing, Ive had a few duff ones that came back to life.
cmeonthemove
  • Taverham, Norwich
Re: Dead battery
« Reply #8 on: 04 June 2010, 19:09:16 »
Will bear that in mind. If I can resuscitate the old one it'll be good for powering my planned model railway at shows. It's an old battery though, one that isn't even a sealed unit.
Now, another question. I remember seeing on here months ago a post about resetting the windows to the one-touch open-close mode, but the search engine cannot find it. Can anyone either point me to the post or advise the button sequence to reset them? Cheers muchly :y
« Last Edit: 04 June 2010, 19:10:54 by cmeonthemove »
Chris
2.5 Elite
  • Auckland
    • Mazda MPV
Re: Dead battery
« Reply #9 on: 04 June 2010, 19:34:47 »
Hold each button in the 'up' position until you hear the relay click.
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
page 123 for the windows
and
page 125 for the sunroof
« Last Edit: 04 June 2010, 19:39:38 by andyh »
cmeonthemove
  • Taverham, Norwich
Re: Dead battery
« Reply #10 on: 04 June 2010, 20:37:32 »
Sorted. Thanks again :y
Chris
2.5 Elite
