Author Topic: Boot release switch  (Read 7470 times)
swamp rat
  • Cornwall
Boot release switch
« on: 30 May 2010, 09:24:54 »
The switch inside the car to open the boot (saloon) does not work. It opens O.K. with key fob and the switch even illuminates when it is open. Is this just a faulty switch or could there be some other reason.
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Boot release switch
« Reply #1 on: 30 May 2010, 09:28:26 »
is there anything eles not woking??? as could be a dodgy fuse, failing that could be a faulty lock
« Last Edit: 30 May 2010, 09:29:55 by Russ76 »
« Reply #2 on: 30 May 2010, 09:33:22 »
I would suggest it has to be switch or its associated wiring.  A meter should confirm.
I have a spare switch should you want me to make measurements....
swamp rat
  • Cornwall
« Reply #3 on: 30 May 2010, 09:33:26 »
Everything else works. Would a duff lock still open with the key fob button.
swamp rat
  • Cornwall
« Reply #4 on: 30 May 2010, 09:36:44 »
Thanks TB. I'll look at the switch first then.
same #same#
  • south yorks
« Reply #5 on: 30 May 2010, 09:37:35 »
yes but no power or the electric pin not working will not open.
« Reply #6 on: 30 May 2010, 09:41:17 »
Whether unlocked via fob or via switch, the very same ECU actuates the very same motor, which rules out motor and associated wiring
same #same#
  • south yorks
« Reply #7 on: 30 May 2010, 09:46:36 »
sorry must be dif type
« Reply #8 on: 30 May 2010, 09:50:57 »
There is only one type with an electric boot release on Omegas (though the ECUs vary, the principle is the same). All other simply lock/unlock boot with central locking :y
« Last Edit: 30 May 2010, 09:51:13 by TheBoy »
same #same#
  • south yorks
« Reply #9 on: 30 May 2010, 09:56:35 »
m8's one the pin had gone and could open with key fob but not switch could hear it clicking, tuck it out and the shaft in the lock was bent, there was a dif of power from opening all doors to just opening the boot just 3volts dif, changed the lock and worked fine after that.
« Reply #10 on: 30 May 2010, 13:45:34 »
Have you tried holding switch in for 5 seconds. Instantaneous press will not release the boot
swamp rat
  • Cornwall
« Reply #11 on: 30 May 2010, 14:02:30 »
Yes, I've tried all these things. It's def a fault of some kind, probably switch, so I'll look there first.
« Reply #12 on: 30 May 2010, 14:42:28 »
Gotta switch here if yours is knackered
« Reply #13 on: 30 May 2010, 17:16:02 »
if its early one, have you tried with key not in ign...
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #14 on: 01 June 2010, 16:31:11 »
Mine works almost instantly.. should it not!?
