Author Topic: remote central locking module  (Read 2442 times)
mossdyke1
  • Aberdeenshire
« on: 10 June 2010, 13:09:17 »
Can anyone tell me where this module is located on my omega 2.2 diesel Elite? sounds pathetic eh but i bought this part of the net trying to get my central locking working, have changed the motor but still not working. HELP pretty please ;)
Re: remote central locking module
« Reply #1 on: 10 June 2010, 13:24:48 »
No, that is actually a very good question! :y :y :y
Hopefully someone will tell us both 8-) 8-)
mossdyke1
  • Aberdeenshire
« Reply #2 on: 10 June 2010, 13:27:01 »
Cheers at least someone is trying to help :)
« Reply #3 on: 10 June 2010, 13:30:48 »
More of the experts will be on the OOF later, and no doubt they will be able to help you ;) ;)
« Reply #4 on: 10 June 2010, 13:31:01 »
Behind driver`s side kick panel
« Reply #5 on: 10 June 2010, 13:35:33 »
Have you checked fuse #20 :question
mossdyke1
  • Aberdeenshire
« Reply #6 on: 10 June 2010, 13:40:35 »
have checked fuse the locks work except the drivers door. I checked the forum and thought it was the motor changed the motor no luck, so bought the remote central locking module. :)
« Reply #7 on: 10 June 2010, 13:48:53 »
Does the driver`s door lock with the key :question
mossdyke1
  • Aberdeenshire
« Reply #8 on: 10 June 2010, 14:43:01 »
key works fine in drivers door. module fitted now but no change still not working propertly >:(
mossdyke1
  • Aberdeenshire
« Reply #9 on: 10 June 2010, 14:57:31 »
will my car need coded after new module fitted???now no locks work with new module oh me this painful :o
« Reply #10 on: 10 June 2010, 17:01:50 »
IIRC needs to be paired to engine ECU and your existing fobs will also need pairing. Before changing the door motor/solenoid did you ascertain whether you had power going to it :question
mossdyke1
  • Aberdeenshire
« Reply #11 on: 10 June 2010, 17:10:33 »
yes power was going to the motor. Have put back in old remote central locking module as it did not work at all. so back to square one.  :(
« Reply #12 on: 10 June 2010, 17:18:46 »
I know it`s a PITA but have you swapped the motor with the passenger side. Depending on outcome, you should know what the problem is
mossdyke1
  • Aberdeenshire
« Reply #13 on: 10 June 2010, 17:29:52 »
PITA is correct, but thanks for all your help. i will renew my efforts tomorrow.
