Author Topic: Headlight level adjustment  (Read 3364 times)
mbraz
  • Hungary
« on: 07 June 2010, 09:10:06 »
Hi All,
I would like to ask your help in the following, my headlight level adjusters are not working. I checked the connections and it seems that everything is properly connected however the engines are not moving if I spin the small wheel under the headlight switch. Can you advise me which is the fuse of the leveler and also if you have any other tips what should I check. ('97 omega, 2 liter with lens headlights)
Thanks in advance
mbraz
Re: Headlight level adjustment
« Reply #1 on: 07 June 2010, 10:38:39 »
Fuses 22 & 31
mbraz
  • Hungary
« Reply #2 on: 07 June 2010, 12:52:58 »
Thanks,
I will check them, but I assume it must be something else then, as none of the two are working... :(
any ideas what else should I check
Thanks,
Mbraz
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #3 on: 07 June 2010, 14:17:58 »
is it auto leveller or one with the switch, as manual (1-2-3)controller is the light switch unit its self. auto leveller is controld by same box but switch is under the car.
« Last Edit: 07 June 2010, 14:18:58 by Russ76 »
mbraz
  • Hungary
« Reply #4 on: 07 June 2010, 15:31:54 »
it is manual (1-2-3) switch, can it be the switch itself, that is not working?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 07 June 2010, 15:57:43 »
Even though the lights are not physically moving, are there any motor noises coming from the lamps when the switch is activated?
Radio & Decoding Technician
www.dndservices.co.uk
mbraz
  • Hungary
« Reply #6 on: 07 June 2010, 15:59:38 »
no, no nise, I even took out the motors to check them and no movement at all.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 07 June 2010, 16:29:19 »
In that case, I think I would probably be starting off next with a  replacement switch
mbraz
  • Hungary
« Reply #8 on: 15 June 2010, 14:57:31 »
I replaced the switch, but no improvement, is there any relay or other fuses I can check or the error is in the wiring? Any ideas?
Thanks,
mbraz
same #same#
  • south yorks
« Reply #9 on: 16 June 2010, 06:06:05 »
take the motors out of the lights and put out on side turn start to 2 on key should see motors go in and out, even with light not on they should move for 1min to 1.30seconds as a reset, also can check for volts at this time. can hear them going just before starting engine., allso check the eath wires under the battery on the bolt.... remember to take the battery off to do the earth wires......
« Last Edit: 16 June 2010, 09:56:46 by Russ76 »
mbraz
  • Hungary
« Reply #10 on: 16 June 2010, 12:35:47 »
Thanks, I will check all these!
