Author Topic: tow bar power electrics  (Read 1956 times)
same #same#
  • south yorks
  • dont blame me im dyslexic
« on: 19 June 2010, 22:26:48 »
white socket what are the colour code for it on omega know need to get a switch or relay to stop live altime and only when its pluged in but what is the code thanks think the plug is a 12v and 230v as has a power converter with the plug. thanks. oh and were would be the best place to put the converter says to keep dry and attach to earth or car. thanks
Re: tow bar power electrics
« Reply #1 on: 19 June 2010, 22:34:26 »
have a look here ....... http://www.motorcycle.co.uk/images/trailer_wiring.gif
12n is the black lighting socket
12s is the white supplementry socket for your caravan battery charging & fridge. There is already a 12 volt feed in the boot under the trim at the back (bumper) edge of the boot, but I suggest you use a voltage sensitive relay
« Last Edit: 19 June 2010, 22:38:20 by Andy_B »
same #same#
  • south yorks
« Reply #2 on: 20 June 2010, 11:14:48 »
thanks andy  :y :y
i will have a look at it .
