Author Topic: indicator help  (Read 2004 times)
andy broon
  • aberdeen
indicator help
« on: 22 June 2010, 20:17:37 »
my indicatos have stopped working now, its not the stalk because i have tried 5differant ones. is there a relay that could have gone? and what relay is it? oye its not the fuse either :(
andy :y
Re: indicator help
« Reply #1 on: 22 June 2010, 20:23:57 »
Do the hazards work :question
charlie
  • sunderland
Re: indicator help
« Reply #2 on: 22 June 2010, 20:24:35 »
Do they light up,but dont flash,do the hazards work??
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
Re: indicator help
« Reply #3 on: 22 June 2010, 20:31:45 »
If the hazards work, but the indicators don't, it's probably the hazard switch...
Strange, I know, but the same happened to me, and it appears that the indicators are wired through the hazard switch?
Swapped out the hazard switch, and bingo! indicators work... swap back, indicators don't work...
Garage said to do with the way GM electrics is laid out.
Fairly easy replacement, and not too steep a price either, about £16 from stealer, but take the old one in, as there are two types apparently...
I always knew I'd inherit an estate, but I never thought this would be it!
andy broon
  • aberdeen
Re: indicator help
« Reply #4 on: 22 June 2010, 21:14:31 »
ye the hazards work dudes, i will try a hazard switch :) cheers
Re: indicator help
« Reply #5 on: 22 June 2010, 21:19:58 »
Switch the hazards on/off about 20 times
« Last Edit: 22 June 2010, 21:20:09 by RobG »
