Author Topic: powersounder  (Read 5747 times)
ivordodge
powersounder
« on: 17 June 2010, 10:37:08 »
i]how do I disable powersounder
Re: powersounder
« Reply #1 on: 17 June 2010, 10:39:25 »
Best bet is to remove the scuttle panel and remove the power sounder completely if it's playing up.
Hannah Judes Dad
    • the misses round the bend
Re: powersounder
« Reply #2 on: 17 June 2010, 23:06:09 »
Once removed tape up the connector with insulation tape,just in case you decide to fit another one.
ScaniaV8
  • Luton, Bedfordshire
Re: powersounder
« Reply #3 on: 18 June 2010, 11:42:02 »
Worth checking your Car Insurance policy schedule details as removing the Alarm/Power sounder could affect any future claims for theft/break-in etc  :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: powersounder
« Reply #4 on: 18 June 2010, 15:38:05 »
I would bet good money on that one
 ::) :-X
Radio & Decoding Technician
www.dndservices.co.uk
Re: powersounder
« Reply #5 on: 18 June 2010, 19:33:23 »
But less likely for the car to go up in flames due to leaking batteries!
If your that worried about theft of a car that  old, you could fit a new p sounder, £50 ish?
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
Re: powersounder
« Reply #6 on: 18 June 2010, 23:47:51 »
How do you stand if you have bought a 10 year old car and genuinely wouldn't know about a disconnected power sounder unless you have read this thread or you are a member of OOF anyway? There must be some people around the country in that position. :-/ :-/
« Last Edit: 19 June 2010, 01:00:32 by mars »
There is no such thing as bad beer, some beers are better than others.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: powersounder
« Reply #7 on: 19 June 2010, 09:37:17 »
Remember that Insurance companies will use any reason possible to back out of a claim. They have professional teams of people who spend their time doing nothing else. Sadly, they actually monitor forums such as these and know all the tricks.
Maintenance of your car is up to you, and has been said, a brand new powersounder is around the £50 mark, so no excuses really.
« Last Edit: 19 June 2010, 09:37:38 by Dave_DND »
Re: powersounder
« Reply #8 on: 19 June 2010, 10:34:52 »
Although my ps has re soldered in batteries. Seems difficult to find the exact right ones though
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: powersounder
« Reply #9 on: 19 June 2010, 11:07:24 »
No problems with that - as long as the sounder has an internal battery pack of some description - its a correct and approved fix as far as I can tell
vauxsky
  • Nr Watford, Hertfordshire
    • Elite 2.5 V6 Man(S_1998)
Re: powersounder
« Reply #10 on: 19 June 2010, 23:12:55 »
Hi, would you beleive it, my PS has been playing up. I have read some of these posts, am I correct in saying the batteries are at fault. My power sounder seems to come on when it feels like it, even when driving.
I will do the Paper CLip test, will this show it up on that too.
Any help appreciated, thanks
Re: powersounder
« Reply #11 on: 20 June 2010, 11:11:59 »
Paper clip and pedal test only read engine ecu, so no.
Ps is fubar, replace. Or unplug short term.
« Last Edit: 20 June 2010, 11:12:33 by chrisgixer »
vauxsky
Re: powersounder
« Reply #12 on: 20 June 2010, 13:45:17 »
Thanks for that, so replace, no repair, above you stated 50 ish, from DND above, Vaux or 3rd party.
To disconnect, is this the procedure:
1. Turn Ignition On - Off
2. Within 15 seconds disconnect Battery Earth, will this stop PS from going off?
3. Unplug Power Sounder
4. Replace, are these all compatible with each other, no need to match?
thankyou for your help
« Last Edit: 20 June 2010, 14:02:55 by dave73 »
Re: powersounder
« Reply #13 on: 20 June 2010, 19:26:57 »
the fact its going off randomly means the battery acid has attacked the board, ps from vx only. Even the latest cars have ps issues so you wont find one trustable second hand, so new only.
Personally i'd just unplug and bin it.
Also note, if cought early enough it possible to solder in new batterys if the circuit board is undamaged. So may be worthcutting open the old one to double check, but it will be fubar.
There are differant internals on model years, so check with dealer.
There are internal pics in maintenance.
tport
  • east mids
Re: powersounder
« Reply #14 on: 20 June 2010, 21:45:47 »
I have just replaced the batteries in my PS with the three leg NiMH batteries mentioned in earlier posts.  A bit of leakage from the old batteries doesn't appear to have affected it.  Although there are two batteries they appear to be connected in series supplying 7.2V onto the PS circuit board
