Author Topic: Air bag light come on - yet not done any work ?.  (Read 2256 times)
SJKOO01
« on: 28 June 2010, 20:17:24 »
As per heading.
Does anyone know where the airbag light would suddenly come on for no reason ?  :-?.
Got to work to day no problem, popped out at lunch break, no problem, then on way back to work, started car as per nomal, and the light came on.
Not worked on car for weeks, and not even touched the airbags.  so stumpped by why it's taken to just switching itself on ?.
charlie
  • sunderland
Re: Air bag light come on - yet not done any work ?.
« Reply #1 on: 28 June 2010, 20:21:45 »
Ive found airbag light coming on and not staying on,to be alternator/battery fault.THe car shuts down systems when not enough power is available.its starts with airbag light then abs and so on hth charlie :y
« Reply #2 on: 28 June 2010, 20:22:32 »
Obvious answer is the system has detected a fault. Need a Decent reader (TechII, "My Naff Code Reader") to establish the problem
SJKOO01
« Reply #3 on: 28 June 2010, 20:29:50 »
1. Doubtful it'll be the battery as the battery's new, so the alternator could be cause then on that point.
2. So who would have Tech2 nearest to me then please, and how much to plug in ?, as otherwise it's a stealer job if too far away !  :-? .
Would happen now wouldn't it, as only just bought some parts for mig to tart her up a bit !!  ::)
charlie
  • sunderland
« Reply #4 on: 28 June 2010, 20:44:43 »
Sorry should have went with Robs answer,my reply was more of a last resort after having system checked  :-/
SJKOO01
« Reply #5 on: 28 June 2010, 20:47:32 »
No worries chap, greatful for any help. So willing to listen to all suggestions. I'm still learning stuff now  :y
Welung666
« Reply #6 on: 29 June 2010, 08:01:19 »
I've got Vaux-Com Matt if you need the airbag codes reading and clearing ;) :y
SJKOO01
« Reply #7 on: 29 June 2010, 17:59:30 »
Would certainly appreciate some help Lee.
Could you pm me to let me know when would be suitable for you to look at it please.
Thanks  :y
« Last Edit: 29 June 2010, 18:06:01 by SJKOO01 »
Welung666
« Reply #8 on: 29 June 2010, 21:05:43 »
Thanks  :y
PM on way :y
SJKOO01
« Reply #9 on: 29 June 2010, 21:19:27 »
Thanks  :y
PM on way :y
Replied  :y
SJKOO01
« Reply #10 on: 05 July 2010, 19:04:41 »
Did you get my last pm by any chance Wellung ?, as pm'd you couple of times, but no reply ??  :-?
