Author Topic: front seat runners  (Read 3800 times)
charlie
  • sunderland
front seat runners
« on: 02 July 2010, 16:33:21 »
Is there a way to manualy move the front passenger side seat(on an elite)as i carnt get at the rear bolts.the seat does move,but no where near enough forward. :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: front seat runners
« Reply #1 on: 02 July 2010, 16:46:18 »
20p, £1 or 1 euro coin jammed in runners?
usual culprit for seats not moving enough, but can take a while to spot them !!
Radio & Decoding Technician
www.dndservices.co.uk
charlie
  • sunderland
« Reply #2 on: 02 July 2010, 16:55:32 »
Tell me about it dave, been on an hour with a torch,got a stiff neck :'( :'(
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« Reply #3 on: 02 July 2010, 17:52:32 »
Take a look at connections under seat.I've had two where they were loose and as I pressed them
in securly they worked again!so just check!!this isnof course assuming the seats don't move at all!!
scream if you want to go faster!!!
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #4 on: 02 July 2010, 23:36:00 »
easy way to get money out that is traped there get a kid in with small hands they can get it out. failing that and motor has ceased up will need to pull the pin out on the motor.
charlie
  • sunderland
« Reply #5 on: 03 July 2010, 13:48:58 »
well i can see the offending coins,thanks for all advise ,cuppa time then back on with it :yOUt now two very buckled 10ps ;D ;D
« Last Edit: 03 July 2010, 14:34:23 by charlie »
« Reply #6 on: 03 July 2010, 15:39:08 »
Mine was a very buckled £1....... a right bugger to get out and Entwood's was a buckled €2 coin  :y  :y  :y
charlie
  • sunderland
« Reply #7 on: 03 July 2010, 15:41:34 »
wish mine was a 2euro coin instead of 20p :y ;D ;D
Hannah Judes Dad
    • the misses round the bend
« Reply #8 on: 06 July 2010, 09:30:09 »
typical foreigners wanting to coming over here and take British jobs  ;D
« Last Edit: 06 July 2010, 09:31:09 by hannahjudesdad »
