Author Topic: Arial roof mount 3.2 mv6 estate  (Read 5525 times)
shaggydog
  • flintshire
« on: 02 July 2010, 20:47:49 »
I've got lousy reception on the radio it seems that the roof mount is faulty,if you move the arial about you can feel the insides moving. What are the three wires for? I know one is the coax, but what are the two black wires for?
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: Arial roof mount 3.2 mv6 estate
« Reply #1 on: 02 July 2010, 23:50:33 »
The roof mount is for the satnav/carphone. The radio ariel is built into the rear window, and is generally crap on all omegas!
« Last Edit: 02 July 2010, 23:51:28 by Lampynoiseboy »
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 03 July 2010, 01:57:39 »
Incorrect, the op drives a late 3.2 MV6 Estate so no Sat Nav or Cell phone equipment installed, the twig on the roof is for FM radio reception. only the very early Mig Esates had the Aerial built into the rear tailgate de-mister window wiring.
« Last Edit: 03 July 2010, 02:14:06 by zirk »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #3 on: 03 July 2010, 10:20:19 »
That's correct but would the loom not be the same and have the cable for sat-nav and phone just not used. Mine is a plod estate but the looms are still there for the extra's(have not checked the ariel one yet)
    • 530D M Sport, 330i Coupe
« Reply #4 on: 03 July 2010, 20:54:40 »
The roof aerial on the estate combines radio and GSM (telephone) as the cars are prewired for phone.
The rear screen aerial on the saloons is usually fine if clean, it's the amp under the parcel shelf that can fail.
shaggydog
  • flintshire
« Reply #5 on: 03 July 2010, 21:15:26 »
Thanks for the info just need to get a new mount now, I think it must have been damaged in it's former life, only had the car since end of march.  :)
Lampynoiseboy
  • SE Essex
« Reply #6 on: 03 July 2010, 22:52:12 »
Ok, so which of you barons is correct then? I'm pretty sure my mates '03 MV6 is rear window....
« Reply #7 on: 03 July 2010, 22:53:12 »
Saloon is rear window, estate is roof.
shaggydog
  • flintshire
« Reply #8 on: 03 July 2010, 22:57:30 »
Quite a debate going on, but it must be roof mount as it's got coax lead. :o
Lampynoiseboy
  • SE Essex
« Reply #9 on: 03 July 2010, 22:58:37 »
Estate combines all 3 in 1 twig?
shaggydog
  • flintshire
« Reply #10 on: 03 July 2010, 23:06:41 »
thankyou everybody that's answersd my question,just got to get the darn thing off without removing to much head linning. :y
« Reply #11 on: 03 July 2010, 23:20:53 »
From my slightly sleepy memory:-
Pop two caps off either side of rear upright trims up boot sides and remove Torx screws
Pull plastic trim from roof (rearmost of headlining) down and unclip from sides
Ease headlining down and use adjustable spanner to unbolt aerial from underneath.
Unclip blue connector from aerial tails to main aerial loom on O/S through gap
« Last Edit: 03 July 2010, 23:23:13 by VXL_V6 »
« Reply #12 on: 03 July 2010, 23:22:23 »
Yes on models equiped with navigation, other models look identical but don't have a GPS receiver in the base.
Lampynoiseboy
  • SE Essex
« Reply #13 on: 03 July 2010, 23:30:12 »
Something to do with the angle of the window i'm guessing.
Very useful  :y
« Reply #14 on: 03 July 2010, 23:35:03 »
Very useful  :y
Aerial is always better performing on the outside with a good ground plane at the highest point (anyone know where there is a big flat piece of metal on a car?  ;D)
Incidentally, Elite and MV6 estates (with tailgate spoilers) have an extra piece fitted between the whip and the base to allow the whip to pivot when the spoiler hits it as you open the boot. Still available from Prodrive I believe.
« Last Edit: 03 July 2010, 23:35:51 by VXL_V6 »
