Author Topic: NCDC 2013 eject  (Read 10603 times)
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
NCDC 2013 eject
« on: 03 July 2010, 00:11:46 »
Ok, after some very useful advice on here (as always) I replaced the duff changer in my HU with a doner CDC3. Followed the guide to the letter, again, very useful.
However...
The cartridge in the changer refuses to eject (so I have no idea if it works as there are no discs in it), although the button seems to work ok (flap open and display says the same), and now my single disc also refuses to eject, and the volume knob turns up & down, but push achieves no on or off- whereas the last 2 items were fine before I breaked about with it!
Help?
Please?  >:(
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: NCDC 2013 eject
« Reply #1 on: 03 July 2010, 00:22:10 »
did you put it in with battery on or off??? dose any thing come up on the display when turn'd on??
Lampynoiseboy
  • SE Essex
Re: NCDC 2013 eject
« Reply #2 on: 03 July 2010, 00:27:32 »
On, and everything else works perfectly, just the ejects & on/off
same #same#
  • south yorks
Re: NCDC 2013 eject
« Reply #3 on: 03 July 2010, 00:30:00 »
take battery off and leave it off for half hour then try it again if replaceing head or any thing should take the battey off to stop faultys coming up.
« Last Edit: 03 July 2010, 00:30:40 by Russ76 »
Lampynoiseboy
  • SE Essex
Re: NCDC 2013 eject
« Reply #4 on: 03 July 2010, 00:35:35 »
I'm 99% sure that half a faulty knob can't be caused by that, but I'll give it a go  :-?
same #same#
  • south yorks
Re: NCDC 2013 eject
« Reply #5 on: 03 July 2010, 00:39:12 »
i know but a sort may have happen'd and only way to see if it has it to disconect battery and try again.
same #same#
  • south yorks
Re: NCDC 2013 eject
« Reply #6 on: 03 July 2010, 00:41:18 »
as most say on here they were fitted by windows so need to reboot ;D
Lampynoiseboy
  • SE Essex
Re: NCDC 2013 eject
« Reply #7 on: 03 July 2010, 00:52:44 »
Do you mean a short? The HU has been out and in again several times since, so I think anything like that would either have fixed itself, if not I can't see "re-booting" the rest of the car would help!
same #same#
  • south yorks
Re: NCDC 2013 eject
« Reply #8 on: 03 July 2010, 02:16:56 »
well only othere thing it would be is a fault with the head unit coss of sparking when the plug has been taken off and on with the battery still on as live all time for memory and has shocked the loader at same time.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013 eject
« Reply #9 on: 03 July 2010, 09:45:00 »
I presume that the CDC3 was working before you ripped it to pieces?
Worth checking that the vertical board that you have transplanted into the CDC3 is seated properly - -
not uncommon for one of the connectors to not be fully "home", so would suggest pulling the board out and refitting it again, just in case.
Radio & Decoding Technician
www.dndservices.co.uk
    • 530D M Sport, 330i Coupe
Re: NCDC 2013 eject
« Reply #10 on: 03 July 2010, 19:19:33 »
Nope
If that was the case the fuse would have blown
Never heard anyone say that on here
Never ever had a problem caused by the permanent 12V on any head unit i've ever fitted or removed.
Personally i'd follow Dave's advice, if it worked (to a degree) beforehand then may be something that was disturbed or not seated properly on reassembly. The cartridge eject problem may have existed on the changer when you bought it.....
« Last Edit: 03 July 2010, 19:21:42 by VXL_V6 »
Re: NCDC 2013 eject
« Reply #11 on: 03 July 2010, 19:26:13 »
Samesame, are you related to Rustym95 by any chance ::)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: NCDC 2013 eject
« Reply #12 on: 03 July 2010, 19:29:15 »
You're supposed to say,
"You are Rustym95 and I claim my five pounds."
 ;D ;D
TuBy's new whipping boy.
Re: NCDC 2013 eject
« Reply #13 on: 03 July 2010, 19:45:31 »
 ;D ;D
;D ;D ;D few quid flying about then. :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: NCDC 2013 eject
« Reply #14 on: 03 July 2010, 19:47:35 »
 ;D ;D
TB will be skint when he gets back off his jollies. ;D ;D
