Author Topic: Dim Speedo and Rev counter  (Read 1868 times)
Will B
  • Oxfordshire
« on: 09 July 2010, 06:48:07 »
Hi all
Hoping this will be a easy fix, I'm guessing one of the bulbs has blown behind my speedo as half of it lights up at night and the other side is dim.
How do you go about replacing these?
And what type of bulb is it?
cheers  :y
Wants an mv6!
Re: Dim Speedo and Rev counter
« Reply #1 on: 09 July 2010, 08:17:28 »
You need to pop the dashboard out to replace bulb - easy job 10 - 15 mins - see howto http://www.omegaowners.com/forum/YaBB.pl?num=1152618876
Also some pics if you search - HTH :y
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« Reply #2 on: 09 July 2010, 10:41:29 »
I'm presuming you have not adjusted the light dimmer on the healight switch??just check it's on full!might sort it!bit does sound like bulb has gone too!easy to change 30 min max!pain to unplug the display though! :y
scream if you want to go faster!!!
Will B
  • Oxfordshire
« Reply #3 on: 09 July 2010, 18:47:39 »
yeah I have checked that lol, I'd of had to leave the forum from shame if it had just been that lol :y
« Last Edit: 09 July 2010, 18:52:00 by wiz1987 »
Wants an mv6!
