Author Topic: Window Close sensor  (Read 2189 times)
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
Window Close sensor
« on: 15 July 2010, 23:40:49 »
Hiya
I obviously have a window closing sensor issue - rear nearside window goes up.. and when about 4 inches from the top, goes down again when you are holding the button
makes it a pain to close, possible only by flicking the switch up to close it cm by cm! - are these easy to repair? anyone got any advice?
Shrek
  • Fife , Scotland
Re: Window Close sensor
« Reply #1 on: 15 July 2010, 23:57:10 »
I had exactly the same issue last year and found if i lubricated the guides at the sides of the window with WD40 or similar it cures it for a while  :y
"My Naff Code Reader" and OBD2 readers available .
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 16 July 2010, 00:06:50 »
both my rears are the same, front n/s also did it, lube didnt help me at all. changed front mech & motor to cure.
Welung666
« Reply #3 on: 16 July 2010, 06:02:17 »
'The sensor is part of the motor mech. and can't be changed seperatly. I've always used taylor's chalk in the runners or a light silicone spray. Check that the rubber channel for the window hasn't been disturbed and is fitted properly first though.
