Author Topic: siemens NCDC2013 CID problem  (Read 2168 times)
mindaz
  • IRL , UK
« on: 13 July 2010, 06:46:55 »
hey pals, one day ago my info display became blury ,
Can it be fixed  ::), or it is dead end for this display ?
How much it will cost £?
Vauxhall/0pel 0mega 2.5 , 2002 , CD
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: siemens NCDC2013 CID problem
« Reply #1 on: 13 July 2010, 12:17:08 »
Not cheap to replace, theres some German ebay guys reckon they can fix them, also other issues about de pairing and pairing the HU and CID if you do get a replacement, but I'll let the experts on here explain that one.
Chris.
Edit, Just noticed you drive a 2.5DTi, so you must already be on the other side of the Channel. That should help.
« Last Edit: 13 July 2010, 12:19:03 by zirk »
« Reply #2 on: 13 July 2010, 18:25:38 »
Looks like knackered LCD panel.  From memory, its a Sharp LQ126AW panel (double check, sticker on back of LCD unit.  Sadly, that panel is obsolete.  LQ136 works in its place, but also difficult to source
mindaz
  • IRL , UK
« Reply #3 on: 16 July 2010, 18:21:57 »
LCD display works again,
thankz for advices  :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 16 July 2010, 19:36:26 »
This is how mine started - it works then it doesn't - then you bang dashboard and it works - over time will just get worse. I bought replacement off German ebay which unfortunately had a fault which The Boy helped confirm and had to send back for supplier to fix - which they did. Has been fine for nearly 3 years now.
zirk
  • Epping Forest
« Reply #5 on: 16 July 2010, 20:05:44 »
Rubber Mallet in boot then!  :y
