Author Topic: Mysterious Flat Battery  (Read 2193 times)
dizaster
  • Ipswich
« on: 12 July 2010, 10:02:03 »
Hi alls.
Got up thids morning to find the car wouldn't start , suspected flat battery ,  but  why ??
Cars been running fine since I've had it  (4 weeks)
Yesterday we attached a towbar ( boot was open for quiet a few hours) ,
Wired the towbar electrics .
Car started when I drove it home .
BUT  this morning nothing  :-(
Cant recall if the boot has lights in it ?? ,  would this of flattened the battery if the boot had been open for ages  ??
Could connecting the towbar electrics (just a scocket on a lead) ,  have caused the battery to discharge ??
Any ideas  :-) ??
Ohhh took battery off to charge today  ,  anything  I need to be aware of when I reconnect it  ??
Many thanks .
Diz
Re: Mysterious Flat Battery
« Reply #1 on: 12 July 2010, 10:20:25 »
Boot does have a light .. butdon't think that would flatten a battery in a few hours .. anyway it started and drove home.
My instant thoughts are the work done ... I wonder if something is remaining powered ??
Did you connect the 12N only (black 7 pin socket) or a 12N and a 12S (grey 7 pin for fridge/reversing lights etc) or a 13 pin socket ?
If more than just a 12N for road lights then you should have added either ignition controlled relays or a smartcom device, if either of those are faulty/in correctly wired they could constitute a drain on the battery overnight .. :(
« Reply #2 on: 12 July 2010, 10:26:42 »
The boot light on mine times out after a few minutes. Not sure if the same on all models?
I would double check the towbar wiring if it goes flat again.
dizaster
  • Ipswich
« Reply #3 on: 12 July 2010, 12:50:14 »
just connected the Black socket, (12N?).
Used those blue  Scotch Connectors and connected the 12N wires to the harness directly ,  no relay or anything , was told I didnt need one .
Car is a '98 (R reg)
wondering if last nights  first night of rain  in weeks had somewthing to do with it   :P
« Last Edit: 12 July 2010, 12:51:26 by dizaster »
« Reply #4 on: 12 July 2010, 13:31:23 »
:o :o
« Reply #5 on: 12 July 2010, 13:50:02 »
No you don't need any relays, but there's better ways of joining wires than using Scotchlocks ie soldering them  ;)  ;)  ;)
dizaster
  • Ipswich
« Reply #6 on: 14 July 2010, 17:43:39 »
LoL  only used the Scotch cause they came already connedted to the wiring harness :-)
Update:  Ripped the wiring out ,  recharged the battery, working fine now.
Checked the socket ,   no shorts between pins.
Next step (This weekend) , reconnect the 12N socket , probably using insulated crimp connectors , just cause i have some, and Im currently out of solder.
Fingers crossed :-0
dizaster
  • Ipswich
« Reply #7 on: 16 July 2010, 22:10:12 »
Starting to do my head in .
We re-connected the towbar socket tonight (No scotch connectors this time  ;))
,  checked for shorts across the pins , all A-OK.
Check the voltages , again all fine ,  but within an hour the car wouldnt start and I needed a jump- to get going again.
While we were connecting the jump cables ,  my friend noticed that the earth lead on the battery was VERY hot .
Anybody got any ideas ??
Cheers
« Last Edit: 16 July 2010, 22:10:55 by dizaster »
