Author Topic: new fault ? headlight / brake light ?  (Read 2599 times)
p.beckwith
  • bedford
« on: 24 July 2010, 23:07:58 »
hi all
 new fault has just appeared on dash ???????
headlight / brake light ????     but all are working ?????
 has appeared just after ive installed rear parking sensor   ???? not connected in any way
  yours  faithfully   paul
Re: new fault ? headlight / brake light ?
« Reply #1 on: 24 July 2010, 23:13:33 »
Bulb blown or you've disturbed one.
Check ALL bulbs .. including those on the boot .. :)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #2 on: 24 July 2010, 23:18:39 »
eliminate the brake light bulb first by fitting GM replacement. Would be interested in your report after doing this.
In March I also posted on ParkPilot problem as well as continuing headlamp range warning when all seems to be working. I had brake light bulb warning intermittently as well but that was definitely resolved by fitting new bulb
« Reply #3 on: 25 July 2010, 02:02:24 »
Probably has halfords bulbs. Replace with GM as said. Remember the system only sees a brake in the circuit and instantly flashes up the message, it does not care if the circuit is completed again.
Ime it's the double filament brake light bulbs most likely to play up.
« Last Edit: 25 July 2010, 02:05:37 by chrisgixer »
p.beckwith
  • bedford
« Reply #4 on: 25 July 2010, 08:14:42 »
all my bulbs are working ???????
 2 x side lights front and rear
 2 x headlight
 3 x brake lights            ??????????
« Reply #5 on: 25 July 2010, 09:43:13 »
 2 x headlight
You've missed the ones in the boot lid ...  :)
p.beckwith
  • bedford
« Reply #6 on: 25 July 2010, 09:53:38 »
boot lid light works  so do both rear fogs and both rear reverse lights
 seems strange that this has come on since fitting rear parking sensors       only cut into the black/white (reverse) and a large brown    (earth)  ?????????
 rear sensors work fine ????????
  paul
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #7 on: 25 July 2010, 10:15:04 »
As said, you should have 6x side light bulbs... two at the front and four at the rear...
p.beckwith
  • bedford
« Reply #8 on: 25 July 2010, 12:32:54 »
with your help    birkhead   found fault    didnt realise there were 4 rear bulbs        wife looked  only at 2     thanks again
         paul
