Author Topic: Aerial problems  (Read 1767 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Aerial problems
« on: 28 July 2010, 13:19:01 »
My 2.2 uses the rear demist in the rear window as an aerial (I think)
It is a 2000 facelift model but I have noticed that vauxhall fitted a roof aerial to cars produced in 2000 & on.
The problem is that I only listen to am radio & it has crap reception. I want to fit an aerial but dont know where the cable is that goes onto the rear demist or whether I could use the cable for the new arial?
Can anyone help!!! :-/
Re: Aerial problems
« Reply #1 on: 28 July 2010, 13:23:46 »
The 'bee sting' Ariel you see is for the GSM phone kit, not for radio  :y
Do you have a standard fit radio?
Omega 37
  • Northampton
Re: Aerial problems
« Reply #2 on: 28 July 2010, 13:35:35 »
I have put in a parrot but was the same with the 2006 multi cd radio.
My dads car is the same but about 6 months newer than mine. It has an aerial on the roof. His is a cd as apposed to my cdx so has the single cd radio, no phone kit  :-?
Re: Aerial problems
« Reply #3 on: 28 July 2010, 14:19:28 »
Aerial amplifier with connections is under parcel shelf just behind centre headrest. You`ll have to remove shelf for access
Omega 37
  • Northampton
Re: Aerial problems
« Reply #4 on: 28 July 2010, 14:31:00 »
Ah thanks would of took a while to find that!!
When I put the rear demist on the reception improves 100% then drops off again. I have to keep switchimg it on & off.  >:(
