Author Topic: interior lights not working  (Read 2395 times)
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
« on: 31 July 2010, 19:38:19 »
okay, so i tried changing the bulb for the driver side door, and while opening it, suddenly all the interior lights went off, now they wont come back on again, help needed :(
Re: interior lights not working
« Reply #1 on: 31 July 2010, 19:56:39 »
Sounds like you may have blown a fuse in the process.
Fazeel
  • Bahrain
« Reply #2 on: 31 July 2010, 22:38:06 »
so how do i fix it now ?
can it be fixed ?
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 31 July 2010, 22:47:07 »
Check Fuse 15, main fuse box, beneath steering wheel.
« Reply #4 on: 31 July 2010, 22:47:32 »
Yep, just find which one it is and change it.
It should be F20 middle row, far right
Fazeel
  • Bahrain
« Reply #5 on: 31 July 2010, 22:51:46 »
Thanx
ok so I'll check both F15 and F 20, but how wud i know if its blown ?
« Reply #6 on: 31 July 2010, 23:00:58 »
Thanx
Remove the fuse and look at it, there should be a continuous strip of fuse wire visable, if you just see a gap then its blown
Fazeel
  • Bahrain
« Reply #7 on: 31 July 2010, 23:09:03 »
Thank alot !
that really helped !
