Author Topic: CDC in boot  (Read 2170 times)
moby
  • Plymouth
CDC in boot
« on: 29 July 2010, 20:30:56 »
help please guys can somebody please point to what these are :cables in loom taped to underside of rear shelf with Din plug end and one with right angle aerial screw type plug,other end is CDC(blaupunkt no`90 565 804)got radio code(working fine with phone) not CDC code
do I need an amp for these.
will try to uplaod pics asap
« Last Edit: 29 July 2010, 20:55:16 by moby »
Re: CDC in boot
« Reply #1 on: 29 July 2010, 23:56:50 »
my crystal ball is not working (no doubt too many beers)
What model is your radio? CDC Refers to the CD Cartridge which is stuck / broken, you don't need a code for this, its a mechanical issue  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CDC in boot
« Reply #2 on: 30 July 2010, 07:45:30 »
Radio & Decoding Technician
www.dndservices.co.uk
moby
  • Plymouth
Re: CDC in boot
« Reply #3 on: 30 July 2010, 08:16:55 »
thanks guys the radio is a CCRT700 with phone option happily that all works ok.car is pre-facelift :(
Re: CDC in boot
« Reply #4 on: 30 July 2010, 11:08:00 »
Sounds like its got a ccrt700.  that is part of the gps system for the on-star functionality (never used in the UK)
Re: CDC in boot
« Reply #5 on: 30 July 2010, 14:08:21 »
You need a seperate code for the CD unit.
What makes you think the OPs CD unit is stuck/broken - maybe the beer  :)
« Last Edit: 30 July 2010, 14:08:39 by dbug »
moby
  • Plymouth
Re: CDC in boot
« Reply #6 on: 30 July 2010, 16:34:21 »
oops sorry have been a cupid stunt,no magazine in CDC,surprise,surprise someones nicked it.thats why its showing fault,as you said.thanks for that.
 I am sourcing mag as I write(ebay) hope they all fit,
will leave update when and if it arrives and works
.moby
Re: CDC in boot
« Reply #7 on: 31 July 2010, 13:05:52 »
I was in facelift mode, CDC Safe (implied with no code) on facelift units means the changer is knackered  :)
Re: CDC in boot
« Reply #8 on: 31 July 2010, 14:25:22 »
Not quite, it means the control board has corrupted itself, which is definately not a mechanical issue ;)
moby
  • Plymouth
Re: CDC in boot
« Reply #9 on: 01 August 2010, 08:59:16 »
many thanks for all the info guys,cant tell much till I put in magazine and see,then as I`m dumb probably more queries
moby :-/
