Author Topic: keeps blowing fuses  (Read 2238 times)
shane1000
  • derby
  • studied nothing for 35yrs so now an expert on it
keeps blowing fuses
« on: 31 July 2010, 17:50:09 »
fuse no. 14 (air con system, blowers etc) its a 30 amp. i've replaced it 4 times in the last 2 weeks . i have'nt got a clue whats causing it . i've also got the little car with spanner picture coming up now and again. any clues anyone?
tidla
  • solihull
Re: keeps blowing fuses
« Reply #1 on: 31 July 2010, 18:21:27 »
sounds like a fan seizing up to me.
on the old escort van managed to free it off with the old wd40 (fitted in the scuttle)
dont know where it is/accessable on the mig?
« Reply #2 on: 31 July 2010, 21:05:55 »
Mine blows when the deivers seat heater gets switched on, have guesed mine is a knackered seat heater.
shane1000
  • derby
« Reply #3 on: 01 August 2010, 12:03:28 »
it only seems to happen when the radio is on. nothing else switched on
« Reply #4 on: 01 August 2010, 12:48:58 »
Has your radio been changed or altered at all, the radio is fuse 12 so seems odd you are blowing fuse 14.
http://www.omegaowners.com/forum/YaBB.pl?num=1161602010
98-2003 cars
1--30A Window operation
2--15A Brake lamps, hazard warning flashers
3--30A Windscreen wipers, windscreen washer system
4--15A Cooling fan
5--30A Electrically adjustable front seats
6--20A Radio
7--30A Electrically operated windows
8--10A Daylight running lamps (Scandinavia)
9--10A Automatic transmission (for the infirm)
10-30A Heated diesel fuel filter
11-10A Heated exterior mirrors
12-20A Courtesy light, tunk lamp, hazard warning flashers, information display, radio, navigation system
13-10A Electrically adjustable exterior mirrors
14-30A Power steering, cigarette lighter, heated front seats, electrically operated rear window blind, air circulation system, electric air conditioning, heated rear window
15-20A Reverse lamps, glove compartment lamp, automatic level control system, cruise control, seat and mirror adjustment, radio, heated rear seats, sun roof, instrument illumination, window operation, cooling fan, headlamp range adjustment
16-20A Fog lamps
17-20A Horn (not the pot noodle variety)
18-20A Fuel pump (useful to remove then run engine to de-pressurise fuel system when changing fuel filter etc!)
19-10A ABS, TC
20-20A Courtesy lamp, seat heating, central locking, rear window blind
21-10A Main beam (left)
22-10A Dipped beam (left) headlamp range adjustment
23-10A Parking and tail lamps
24-20A Coolant heating
25-20A Sunroof
26-10A Number plate lamp, information display, headlamp washer system
27-20A Automatic level control system, rear accessory socket
28-20A Fog tail lamp
29-30A Terminal 30. constant current for caravan/trailer (pikey optional fit, can be used for simple audio instals)
30-10A Parking and tail lamps (right)
31-15A Dipped beam (right), headlamp range adjustment
32-10A Main beam (right), control indicators
33-30A Heater fan, air-conditioning system, electric air-conditioning system (climate)
34-40A Heated rear window
shane1000
  • derby
« Reply #5 on: 01 August 2010, 16:19:06 »
as far as i know everything is standard and nothing changed ... 2 fuses in last 2 days.
« Reply #6 on: 01 August 2010, 19:57:41 »
Check all connections and wiring under driver`s seat. May have to be a battery off, seat out jobbie
