Author Topic: alarm system / imobiliser 95 td omega  (Read 1599 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 02 August 2010, 13:33:15 »
i'm breaking it up for bits
it has the very old type of ignition key ( 2 buttons / looks like a infra red lens on it )
did this modal have a transponder in the key for a imobiliser ?
ive stripped the plastic from around the column and there is no transponder round the ignition barrell  :-/
the car has had a toad aftermarket system fitted  ( a 200 plus )  before  i got it
need to know because the diesel pump / ecu is coming out to sell  so i can make some dosh for work on my v6
cheers steve
Re: alarm system / imobiliser 95 td omega
« Reply #1 on: 02 August 2010, 13:46:13 »
If it has a 214 or 215 ECU, the immobiliser is simple, no transponders.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 02 August 2010, 14:52:05 »
just checked ............ its a 214  :y
i take it that it has no imobiliser circuit hence the last owner fitting the toad ?
is the ecu paired up with the diesel pump ?
if so, any idea what its worth ?
all moneys recieved will be going into the pink ones back pocket  ;) ;D
« Reply #3 on: 02 August 2010, 15:33:52 »
The immobilser is a simple on/off single to ECU.  Pump not paired, but there is a complex chart of which ECUs can be used with which pumps. Gnerally newer ECUs can use older pumps.
