Author Topic: Depairing CID  (Read 1960 times)
joshwyatt
  • Oxford
Depairing CID
« on: 05 August 2010, 16:16:58 »
To remove a CID from an Omega, do you need the car pass? I know it's a tech2 job as it's coded to the HU and the car, but if a tech2 is plugged in, can you simply put it in delivery mode and then remove it from the original vehicle ready to be fitted to another Omega?
Re: Depairing CID
« Reply #1 on: 05 August 2010, 16:28:42 »
its not a simple tech2 to de-pair it, it has to be (as you say) be put into 'Delivery Mode' TB has a way of doing it but its not guaranteed to work, it could make the CID toast...
« Last Edit: 05 August 2010, 16:29:12 by tunnie »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Depairing CID
« Reply #2 on: 05 August 2010, 16:32:01 »
Fairly certain you need the car pass, unless your moving both the CID and HU together, probably wrong, no doubt will find out.
Re: Depairing CID
« Reply #3 on: 05 August 2010, 19:28:40 »
Joshwyatt, in your case, carpass not needed, but it is a PITA.
Is the CID paird to NCDC2013 or 2015?
