Author Topic: Are the MIDs 'paired'?  (Read 1879 times)
« on: 10 August 2010, 20:43:52 »
I've seen plenty of posts about CIDs being paired (to a specific stereo, I suppose) and therefore to buy an unpaired one so it can be paired with a Tech2 ..
Are MIDs paired? I'm guessing not, since I don't recall anyone mentioning it, but then most people do seem to be talking about later (nicer, grumble  ;D ) cars.. :)
Re: Are the MIDs 'paired'?
« Reply #1 on: 10 August 2010, 20:46:57 »
nope.
But are programmed for correct configuration.
« Reply #2 on: 10 August 2010, 20:51:08 »
Gotcha :)
I have a brand new-old stock MID sitting in a box to replace my dead-pixel special, so I imagine I'll need a trip to someone with a Tech2 once it's in then. Unless it's only the radio settings that need programming (rather than the general display)? In which case I might just ditch the factory tape player and fit something else (and, thus, no longer need the radio segment of the display)..
« Reply #3 on: 10 August 2010, 20:59:37 »
If its the right type (your profile implies yellow and black plugs), that just needs Model (Omega), engine and gearbox configs programmed in.
Later MIDs need a bit more configs, but same applies really.
CCRT displays are like later mids (although it is possible to program as a TID variant).
GIDs and CIDs, as well as pairing, need configuring with even more config options than MIDs
« Reply #4 on: 10 August 2010, 21:01:57 »
I see, thanks!
And you're right - it's a two-plug MID rather than the (later, IIRC) single plug.
In that case, when I finally get my arse into gear and get around to this job, I better get in touch with my nearest Tech2 person :)
Thanks again!
« Reply #5 on: 10 August 2010, 21:06:37 »
I see, thanks!
Thanks again!
I would recommend Kevin Wood - he knows how to use the tech2 :y
