Author Topic: Paperclip test has screwed my electrics  (Read 6114 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Paperclip test has screwed my electrics
« Reply #15 on: 12 August 2010, 15:25:32 »
Where are you located?
Somebody nearby may be able to glance a your electrics for you.
Radio & Decoding Technician
www.dndservices.co.uk
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #16 on: 12 August 2010, 16:19:52 »
something is amiss, way beyond the stereo by the sounds.. !
MrDJ
« Reply #17 on: 12 August 2010, 16:33:44 »
Banbury, oxfordshire.
You don't think it might be the relay then?
  • Auckland
    • Mazda MPV
« Reply #18 on: 12 August 2010, 22:57:21 »
Before doing anything else I would check that all the fuses are seated properly in the fusebox.
The OBD test socket is in the middle of the fusebox and maybe one of the fuses has fractured and decided to start playing up now after being disturbed slightly :-/
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
« Reply #19 on: 13 August 2010, 12:34:47 »
Paperclip test aint no good boy
MrDJ
« Reply #20 on: 13 August 2010, 12:58:07 »
ok I tried a new relay and no buzzing but dead so reading about the fuse suggestion I set about removing and testing every single fuse once again  (it was one of the first things I tried).
I found a 20 amp dead fuse and low and behold everything seems back to normal. I must have missed the only dodgy fuse the 1st time round doh! I haven't tried the stereo yet as I'm at work but fingers crossed all will be ok.
Thanks to everyone for their suggestions in this thread as I was close to giving up..
To say I'm happy is an understatement as I was thinking id wrecked the ecu.
Now to crack on with the rest of the problems my omega has, you lot will be sick of me soon :)
Thanks again...
Page created in 0.023 seconds with 20 queries.
