Author Topic: safe mode!!!  (Read 2848 times)
jason120
  • chard. somerset
safe mode!!!
« on: 14 August 2010, 12:40:15 »
hi guys the battery went flat on my elite last night and now its just saying safe mode (havent tried putting code in) i have the code but it wont let me do anything anyone no how to fix this as i hate driving without music and dont really wanna change the head unit many thanks jason
Welung666
Re: safe mode!!!
« Reply #1 on: 14 August 2010, 12:44:03 »
Which model head unit?
jason120
  • chard. somerset
Re: safe mode!!!
« Reply #2 on: 14 August 2010, 12:45:28 »
i think its a ccr800
Welung666
Re: safe mode!!!
« Reply #3 on: 14 August 2010, 12:54:22 »
Ignition on, radio off. Press and hold the AS button and switch the HU on, it will beep and then request a code, release AS button. Use buttons 1, 2, 3 & 4 to enter the code then press AS again :y
« Last Edit: 14 August 2010, 12:54:40 by Welung666 »
jason120
  • chard. somerset
Re: safe mode!!!
« Reply #4 on: 14 August 2010, 12:56:24 »
cheers mate will go try this watch this space!! :y :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: safe mode!!!
« Reply #5 on: 14 August 2010, 17:20:27 »
SAFE with no numbers to the left means that igntion was not turned on first.
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Radio & Decoding Technician
www.dndservices.co.uk
Re: safe mode!!!
« Reply #6 on: 15 August 2010, 09:49:17 »
Turn Off Stereo
I think that guiide could be clarified with a 'Ensure radio is off' after the switch ign on stage :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: safe mode!!!
« Reply #7 on: 15 August 2010, 17:19:18 »
Turn Off Stereo
You are right there !!  My mistake !
mrhoots
Re: safe mode!!!
« Reply #8 on: 16 August 2010, 15:59:06 »
if you put in the wrong code initially is there a length of time before you are able to put thr correct code in and do you need to have the ignition on? Please help.  :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: safe mode!!!
« Reply #9 on: 16 August 2010, 16:24:11 »
Yes, and the time gets longer each time an incorrect code is entered. Yes, ignition has to be left on, often for hours at a time and remember that you do not get infinate attempts either.
Have a look at my website if you need a correct code though, its a lot less painless in the long run !!
mrhoots
Re: safe mode!!!
« Reply #10 on: 16 August 2010, 16:30:16 »
Thanks Dave, just as i suspected. When i originally put in the wrong code, twice, there was a figure in brackets saying 09 and then 08. I assume this will be the number of attemps I have left to put the code in correctly, I hope?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: safe mode!!!
« Reply #11 on: 16 August 2010, 16:59:02 »
Yep, and from 07 onwards you run the risk of flattening the battery with the ignition on for such a long time.
What model radio are we now referring to?
Re: safe mode!!!
« Reply #12 on: 16 August 2010, 17:06:07 »
There is a sperate thread now...
Page created in 0.022 seconds with 20 queries.
