Author Topic: Replacement Stereo  (Read 2231 times)
rajveer.sandhu
Replacement Stereo
« on: 16 August 2010, 11:23:29 »
Hi guys,
Ive decided to replace my Bose Setup with something newer.
I was thinking about getting the Pioneer FH-80BT (Double DIN) stereo. What else would I need (connectors for MID, steering wheel etc.).
Or can anyone else recommend another setup?
All I really need is for it to play MP3s,WMA etc., have a USB input and also be able to connect my Subwoofer and Speakers to it.
Raj
Re: Replacement Stereo
« Reply #1 on: 16 August 2010, 11:24:22 »
Presumably, you are changing all the amps and speakers?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 16 August 2010, 11:42:26 »
BOSE amplifier is not compatable with aftermarket head units, and teh BOSE speakers are 2 Ohms, so they will also need to be changed if going aftermarket.
Radio & Decoding Technician
www.dndservices.co.uk
rajveer.sandhu
« Reply #3 on: 16 August 2010, 12:05:01 »
Yep, I'm changing subs, amps and speakers.
Any suggestions?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 16 August 2010, 12:18:26 »
This is still proving to be immensely popular !!
http://www.dndservices.co.uk/cx609e.html
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #5 on: 17 August 2010, 11:06:03 »
just a question - what is the actual issue - only I happened to be passing an ICE dealer I have used for years for bits and pieces and the techy bloke said there is no issue with the right head unit.. Obviously I was "Er are you sure" but wondered what the issue is as Stereo man says there isn't, but its well documented on there that there is.. ?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 17 August 2010, 11:55:45 »
The problem is that the BOSE head unit uses non-standard line level voltages, and the RCA voltage converters from just about every manufacturer out there do not allow correct operation - tell that to the techie guy and see if he has a solution - but I doubt it.
