Author Topic: HID v Halogen  (Read 3127 times)
mrjimbo
  • Oxfordshire
HID v Halogen
« on: 17 August 2010, 16:02:11 »
Which would draw most current a HID bulb or a normal Halogen bulb ?
Just curious, something i've often wondered  ;D
Re: HID v Halogen
« Reply #1 on: 17 August 2010, 16:05:23 »
IIRC HID's are 35W and your halogen tunsten type are 55W
V=IR if you want the current.  :y ;)
Re: HID v Halogen
« Reply #2 on: 17 August 2010, 16:07:09 »
Higher for initial power up then less when "up and running"
I_want_an_Omega
Re: HID v Halogen
« Reply #3 on: 17 August 2010, 20:57:17 »
HIDs have a power supply which fire up (which is why they "flash" when powered up) at a couple of thousand volts and then back-off to run at a hundred volts or so. The power supply is the metal box screwed to the headlight and have an "HT" cable to the bulb.
The technology is the same principle ss a flourescent light - and also the backlight on a LCD tv.
The inrush current when HIDs fire up is very high - at about 20amps, this reduces down to about 3amps when they stabilise which takes a few minutes.
pedroMV6
  • York
  • Der Metzgermeister
Re: HID v Halogen
« Reply #4 on: 17 August 2010, 21:03:06 »
Just a couple of ordinary wires inside......... ;)
I_want_an_Omega
Re: HID v Halogen
« Reply #5 on: 17 August 2010, 22:32:14 »
Yes, with lots of insulation around them.
